Ideas/ sources for foot accurate outdoor navigation, mapping GPS hacks, beacons...?
Hey Everyone,
I was wondering if anyone has had any experience with foot accurate outdoor navigation systems? Even being accurate to 5 feet in a football size field would be good enough. Has anyone worked with mapping or survey quality GPS systems that can be read by a microcontroller (propeller)? Any suggestions? IR beacons, multiple normal GPS, hacked smartphones?
Dave
Dave
Hal
Can someone take a look at the manual and help me to understand if this is something that the Propeller could interface with?
Update: I see it uses RS-232C so I'm guessing that its a yes?
Consider also that the cm error could be lost for short periods even in the open field. If you are in an area with trees, for instance, you'll have problems getting a fixing and the error will be much higher nonetheless.
Massimo
