Hackable electronics for cheap — Parallax Forums
pedwardpedward Posts: 1,642
edited 2013-04-10 09:59 in General Discussion
I was as Rite-Aid with my wife this afternoon and saw a USB plug-in blood glucose meter. I thought it was kinda cute, then my wife pointed out it was only $5 bucks!
The device is the Bayer Contour USB (http://www.bayercontourusb.com/)
It was $29.99 and had a $24.00 instant rebate with wellness card.
I picked one up and took it to the register and purchased it for $5.99!!!
I immediately took it apart when I got home and took the attached pictures, this think has a bunch of hackable stuff in it.
The microcontroller is an STM32F103 and it has a 4Gb Toshiba flash on board (rather difficult to find info).
The display is a somewhat low res OLED color display. I tried to count the pixels on the display, but I got a weird number like 58 pixels tall. I'm guessing the picture wasn't the best. I would estimate it to be a 64 pixel tall by 192 wide.
I bet the display is worth $5, but I'm thinking the whole think could be re-programmed into something neat, the processor has 256KB of flash memory and is an ARM Cortex M3.
    edited 2013-03-10 18:28
    WHy the heck does it have that much flash .! .....Cool ! but Dang I can run a entire Linux distro on that with room to spare .... I hope it has a JTAG and a few usefull pins to prod.....
    Peter
  • Mark_TMark_T Posts: 1,981
    edited 2013-03-10 20:08
    Peter
    Maybe its the cheapest flash chip currently in volume production?
  • pedwardpedward Posts: 1,642
    edited 2013-03-10 22:22
    On the box it says "2000 test memory" and "500MB" extra memory.
    When you plug it into a computer, it enumerates as a storage device with 511.7MB free. Given that 4Gb of flash is 512MB, 2000 test samples obviously doesn't take much space!
    I'm thinking this think is probably very hackable, given that ST makes dev tools easily available, and it's a run-of-the mill part.
    The hard part would be knowing how all of the I/O is mapped.
    Then again, I wonder if there is even any code protection enabled...
    edited 2013-03-10 22:23
    Check this out: http://www.bayercontourusb.us/Special-Offer
    It's a $5 off offer, which makes the whole thing only cost 99 cents!!!
    edited 2013-03-10 22:49
    The plot thickens, now after looking further, there is more than 512MB of storage on the unit:
    /dev/sde 410M 39M 372M 10% /media/GLUCOFACTS_
    /dev/sdd 512M 0 512M 0% /media/CONTOUR USB
    There are 3 devices presented:
    GLUCOFACTS
    GLUCOFACTS_
    CONTOUR USB
    Between them there is ~922MB of storage on the device. Perhaps my reference for the flash chip was inaccurate, as I believed it was 4Gbits.
    The info gets even cooler, from: http://www.toshiba.com/taec/news/press_releases/2008/memy_08_536.jsp
    The device is an embedded 1GB SD memory!!!
    References:
    http://datasheet.octopart.com/THGBM2G7D4FBAI9-Toshiba-datasheet-11573603.pdf
    578 x 392 - 57K
    edited 2013-03-10 23:10
    Here's a dump of the USB info. The interesting part is that it enumerates an HID device--a mouse! The Java program that comes with it has a few DLL files, there is a reference to the following devices (their names):
    BayerHID00
    BayerHID01
    BayerSER00
    The device only enumerates as a full speed device, so it's not that fast.
    Bus 002 Device 046: ID 1a79:6002 Bayer Health Care LLC
    Couldn't open device, some information will be missing
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            0 (Defined at Interface level)
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x1a79 Bayer Health Care LLC
      idProduct          0x6002
      bcdDevice            1.00
      iManufacturer           1
      iProduct                2
      iSerial                 3
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength           64
        bNumInterfaces          2
        bConfigurationValue     1
        iConfiguration          4
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              500mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceClass         3 Human Interface Device
          bInterfaceSubClass      0 No Subclass
          bInterfaceProtocol      2 Mouse
          iInterface              5
            HID Device Descriptor:
              bLength                 9
              bDescriptorType        33
              bcdHID              10.10
              bCountryCode            0 Not supported
              bNumDescriptors         1
              bDescriptorType        34 Report
              wDescriptorLength      38
             Report Descriptors:
               ** UNAVAILABLE **
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x01  EP 1 OUT
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0040  1x 64 bytes
            bInterval               1
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceClass         8 Mass Storage
          bInterfaceSubClass      6 SCSI
          bInterfaceProtocol     80 Bulk (Zip)
          iInterface              6
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x02  EP 2 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x82  EP 2 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
    edited 2013-03-11 00:15
    4Gbytes of good Flash is worth $5USD.
    edited 2013-03-11 01:20
    It turns out to be only 1Gbyte, but eSD, so easy to interface. I pulled the data sheet for the mcu, and it has a serial boot loader, I bet one of the test points on the bottom is this USART port.
    edited 2013-03-11 01:26
    Mark_T wrote: »
    I suspect it is because they wanted to package the pc software for interfacing with the meter, and 1GB was the smallest denomination. The JAVA tool consumes 40MB, but they allow you to save reports an stuff.
    edited 2013-03-11 15:43
    That thing is so new the paint is probably still wet on it. I might have to think about grabbing one -- for actually checking my blood sugar. The test strips are half the price of the OneTouch Ultra strips I've been using.
    edited 2013-03-11 16:30
    Yeah, go to Rite Aid, sign up for a wellness card, and present the coupon generated by the rebate link above, and you can have a glucose meter for only 99 cents!
    It comes with the USB meter, USB extension cable, 550ma USB charger, lancet device/sticker, 10 lancets, and a carrying case.
    Retail price is $29.99 without any rebates, the Rite Aid instant rebate is $24.00, the manufacturer coupon is $5.00.
    edited 2013-03-13 00:25
    I have some new info about this device. The display is 160x58 pixels and I'm pretty certain the controller is an SSD1353, since that number is silkscreened into the FC attached to the display.
    Here's the info: http://www.solomon-systech.com/en/product/display-ic/oled-driver-controller/ssd1353/
  • UllasmannUllasmann Posts: 1
    Hi Peward.
    If this thread is still open, I thought you might be interested in the following Pads/Pinouts diagram for the Bayer Contour usb device?
    Greets from Germany.
    Ullasmann.
    1024 x 630 - 97K
