pinstatus LEDs — Parallax Forums
pinstatus LEDs
ErlendErlend Posts: 612
edited 2013-03-10 08:03 in General Discussion
In a project I am doing I would like to have LEDs tell the status of all prop i/o pins, irrespectly of wether thay are configured as input or output. This means the LED driver must have a high input impedance, be controlled by individual digital inputs, and be 3.3V compatible. I need advice about what would be a good multichannel driver chip - and where it can be obtained? I have a few 4007, but they are only 4-channel - which means a lot of soldering and PCB space. Cannot find it in the google jungle.
Erlend
    edited 2013-03-10 03:43
    The 74LVCxxx series logic is quite new and only available is surface mount, but it is a good choice for working with the 3.3 volts of the Propeller.
    These can be powered by 3.3v to behave as 3.3v logic, or powered at 5.0v with 3.3 logic inputs to output 5 volt logic levels. Indivdual ICs have different capacities to provide the extra power you need.
    But the real concern is if you want these to be bi-directional to all 32 i/o pins and provide LEDs in both directions. It might be easier to have each i/o pin drive a two-color LED and have each i/o pin provide a bi-directional buffer as well.
    Generally bi-directional buffers can only switch directions of banks of 4 bits, 8 bits, and so on. If you want each and every i/o pin independent, you may have to provide another scheme.. such as an individual MOSfet as a bi-directional i/o buffer on each and every pin.
  • Mark_TMark_T Posts: 1,981
    edited 2013-03-10 05:05
    4 x 74HC245 should do the job - modern hi brightness LEDs only need a few mA to be nice and visible, the
    244 is an octal buffer with enable/direction inputs (so you can easily turn the LEDs all off if you want). The 74HC
    series goes down to 2V supply and is cheap.
    Note that when pins are inputs the threshold voltages of the Prop and the 245 will not be the same so when
    used as analog inputs the LED state won't necessarily match the Prop's INA register - proper logic levels
    would be fine though.
    [though the prev poster's suggestion of the LVC family would handle higher currents if the LEDs aren't so bright,
    the HC family can do about 5mA at 3V3, LVC 24mA]
  • ErlendErlend Posts: 612
    @Mark_T
    Although I do not need the bidirection function, this looks perfect. A nice feature to be able to switch them all off too. Now I need to find where to buy a handful.
    Erlend
