Anyone interface Wiimote with propeller using Bluetooth?
Searching the forum has led to several projects involving cannibalizing Wiimote hardware for direct connection to a Prop. I'm looking for a way to interface an OEM Wiimote to a Prop, using only the bluetooth interface. The RN-42 information seems to indicate it can't support this, if I'm correct that the Wiimote requires HID support but the RN-42 only supports SPP.
Has anyone been able to interface an OEM Wiimote with a Propeller using Bluetooth?
As rwgast suggests, all the Propeller Wii Mote projects I've seen use the hacked camera.
Chris the Carpenter sells the cameras through his Rocket Brand Studios. IMO, Chris sells good stuff and is a good guy to deal with.
If you do figure out the Wii Mote with Bluetooth using the Prop, I hope you let the rest of us know. It would be very convenient not to have to destroy a Wii Mote in order to use the camera with a Prop.
