433 Mhz Transceiver
Hello guys,
I plan on using two 433 MHZ transceiver, each connected to a PIC24H microcontroller, in order to send data to each other ( 1 is the TX, the other is the RX).
Does anyone have the library for use with the transceiver that is being sold by this vendor? Anyone ported it to C or C++? ( all the neccessary function etc..)
I am using MPLAB in order to compile my code.
Has anyone use this transceiver with the PIC family of MCU before?
I am only using them to send a temperature value.
They're pretty straightforward to use and the Stamp examples shown in the documentation can be transliterated to code for pretty much any microcontroller. You need a sync pulse (about 3ms) that turns on the transceiver briefly to allow the receiver at the other end to adjust to the received signal level, then you use ordinary asynchronous serial I/O to transmit the data. There's no error checking or correction, so you have to build that in using software if it's important. There are some examples of that linked from the webstore page for the product.
