Balloon material
NWCCTV
Way back when, when I was a kid there use to be a product on the market that you could make blow up balloons, animals, etc. with. This stuff was really cool and came with a straw and you would blow in to it and shape your balloon. Does anyone remember this stuff and possibly have a clue as to what it was called and where to get it?
Edit: I just found it. It was made by Whamo and it was called Super Elastic Bubble Plastic. Now I just need to find some!!!
Edit: It looks like it is no longer available. I guess too many people liked the fumes too much. Does anyone know of something similar to this product?
Darn, I hadn't read your edit. Now how will I impress people with my useless knowledge.
I don't think it's available because the fumes weren't very healthy and it was easy to breath the fumes back in through the straw.
I majored in chemistry and was surprised to find ethyl acetate smells just like S.E.B.P. Ethyl acetate must have been it's main solvent keeping it soft.
When I worked at the university chemical stockroom, we sold ethyl acetate to biology classes to use in their "kill jars". They'd place bugs in the "kill jar" along with ethyl acetate and the bugs would soon be dead.
Why would they take something as fun as S.E.B.P. off the market?
Just be careful of how flammable it is. Don't breathe the fumes, get it on your skin, or the skin of others, etc.
http://en.wikipedia.org/wiki/Super_Elastic_Bubble_Plastic
http://www.ebay.com/itm/Polyvinyl-Alcohol-PVA-One-Pound-Lab-Chemical-/251239460980?pt=LH_DefaultDomain_0&hash=item3a7f09f074
http://www.ebay.com/itm/Ethyl-Acetate-500Ml-Poly-Bottle-Reagent-Chemical-/110998222168?pt=LH_DefaultDomain_0&hash=item19d8027558
might be close?
I haven't seen your original material, but from description it looks just like the substance I mentioned above, so you may try it too. I used compressed air bottle (used to clean keyboards) with it, got quite nice, stay-solid-longer bubbles, but they were sticky.
On the other hand, I did once work for a manufacture of balloon making machines. And we did have machines that made and tested balloons made from latex rubber. These are rather simple. They dip a shape into the latex solution and then a rubber balloon was removed from the form by a worker. It's the same process for surgical gloves, and other more exotic devices that prevent pregnancy.
So, is this really about balloon material or long lasting bubble material?
Latex rubber is one balloon material, another is metalized mylar.
http://www.partycity.com/product/pint+of+latex.do
I painted this stuff on rip stop nylon to make reinfoced balloons. Needs to be on the INSIDE of the cloth to hold very much pressure. I later switched over to Mylar balloons inside the ripstop envelope, but I was going for max pressure, these could hold 40psi.
