Cannot get piezospeaker to "beep" in activity three
Hi
Need help.
Trying to run run the Start/Reset Indicator circuit and while the program runs and gives the expected messages, I cannot get the speaker to "beep"
I have checked the wiring and code and everything seems right.
Questions:
What setting should the on/off switch be set at - 1 or 2.?
Does it matter what colour the jumper wires are?
Could the batteries be going flat and affecting the "beep"?
Any help would be appreciated.
Regards
Need help.
Questions:
Regards
"What setting ... ?" - Either switch setting should do. The difference between setting #1 and setting #2 is that power to the servo sockets is only on in position #2.
"Does it matter what colour ... ?" - No. The colour is for your benefit (and that of others who may look at your project) to indicate what signal is carried in the wire. Usually red indicates (+) or Vdd while black indicates (-) or Vss or ground (earth).
" ... batteries ... flat ... ?" - Maybe, but it's more likely that the wiring is incorrect.
