Cheap stepper motor and driver — Parallax Forums
LeonLeon Posts: 7,620
edited 2013-04-25 10:48 in General Discussion
I bought a stepper motor and driver board which has been mentioned here previously from a UK supplier (£5.19 with free postage) which seemed like a good deal, but I just found the same thing from a Hong Kong supplier for £1.66 with free postage:
http://www.ebay.co.uk/itm/5V-Stepper-Motor-28BYJ-48-With-Drive-Test-Module-Board-ULN2003-5-Line-4-Phase-/200712530295?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item2ebb662977
which is incredibly cheap.
The motors were apparently intended for controlling ventilation louvres, which explains their low cost.
I'm working on a simple assembler test program for a PIC16F88, primarily because I had a suitable home-made prototyping PCB and it seemed to be a waste of a much more expensive Propeller proto board.
Because of the gearing these motors aren't much use if a rapid response is required, but they are ideal for educational purposes.
    edited 2013-03-08 03:51
    This would be very easy to explore with the Propeller Protoboard, and you would have more options to expand. I recently used PropForth to drive a pair of cheap steppers with a UNL2803 chip.
    with Forth on a Propeller, you can deal with what the stepper motor is doing in real time. This really speeds up tasks that require accurate positioning and calibration. Once you lock in the right rates and positions, you can extend your Forth words into a complete routine.
    Either PropForth or Tachyon Forth are available.
  • LeonLeon Posts: 7,620
    edited 2013-03-08 05:06
    I got it working without any problems, apart from getting the connecting wires on the wrong pins on the PIC. The LEDs on the driver board were very useful, in conjunction with the single-step facility available with the MPLAB debugger.
  • AdyenAdyen Posts: 7
    edited 2013-03-08 05:57
    Leon wrote: »
    Well i think its great man and as you define it should be run in same manner as you define. I will definatly try it because it seems to me very intresting.
  • pjvpjv Posts: 1,903
    edited 2013-03-08 08:21
    Leon;
    Thanks for the find.
    Plan to order a bunch today to drive many small ball valves to modernize (network) our building's water based heating system.
    These should be perfect for that, and I sure like the price.
    Cheers,
    Peter (pjv)
    edited 2013-03-08 08:25
    I'd not heard of ball valves before, so I looked them up:
    http://en.wikipedia.org/wiki/Ball_valve
    They should be ideal for that, so long as you don't need too much torque. Of course, the gearing gives a lot more torque that you would get from similar motors without gearboxes. I found the data sheet:
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CDIQFjAA&url=https%3A%2F%2Fbitbucket.org%2Ffdion%2Fpi-a-sketch%2Fdownloads%2FStepper-Motor-28BJY-48-Datasheet.pdf&ei=pxM6Uee4G4yV7Ab2roDACQ&usg=AFQjCNHR_elifp8Bc6S93VORL4Oh7b5KxA
    That is for a 12V motor whereas the one I've got is marked 5V, but it should be OK for mounting dimensions etc.
    edited 2013-03-09 02:52
    The 1:64 gearing makes these very attractive, along with the 5Volt operation and ULN2003 included.
    Most of the time, positioning doesn't have to be a fine grained as a stepper provides, and speed is a bit of a non-issue as well. I like the idea of using a ball valve is that don't tend to stick in an open or closed position. That stickyness of a conventional faucet with a valve seat makes electronic control much harder to implement.
    edited 2013-03-09 11:24
    Unfortunately those those cheap steppers have lots of backlash (5-8 degrees) and very little torque. They are useful for small projects and education. I suspect a tiny ball valve might work if little torque is required. There are very tiny plastic gears inside which would wear, strip, or break under load.
    edited 2013-03-09 12:09
    That seems like a lot of backlash. Has anyone actually measured it?
  • tritoniumtritonium Posts: 547
    edited 2013-03-09 14:57
    Hi
    Yes I'm using them on my robot and so I just checked. I dont have anything to measure angles but-
    I get backlash of 1/16 inch.
    Wheel diameter is 2 7/8 inches.
    So circumference is 9.022 inches.
    backlash = 360 / (9.033 x 16) = 2.5 degrees.:nerd:
    (hope I'm right)
    Dave
    edited 2013-03-09 15:03
    Hi again
    And while I'm at it I would say they are ok for non critical use. The torque is not great - it seems a lot with the shaft turning and you pinch it with your fingers, but with a 3 inch wheel attached it is easy to make it miss a beat. Actually I'm driving them at 10volts and they get warm but as long as they keep going I will continue to abuse them.:thumb:
    Dave
    edited 2013-03-09 17:59
    Thanks Dave.
    I expect they'll be fine for my purpose. I've asked for 100 to be shipped so hope t have a lifetime of spares. I plan to run a serial network around the building ...propeller driven of course... to sense temperatures, control these motors as heat zone valves, control lights, building access as well as employee task logging. Figure a hundred nodes or so, and probably controlled by Hanno's 12 Blocks. Ought to be a fun project.
    Cheers,
    Peter (pjv)
    edited 2013-03-09 21:09
    Frankly, I had never before considered the possiblity of geared stepper motors as all that I have seen were direct drive and you had to provide your own gears.
    I suspect that if they are not quite right for Peter(pjv), there will be an easy resale market.. especially at these prices.
    It might help significantly to really deliver 5 volts to the motor. The ULN2003 and related Darlington chips can have an internal voltage drop of as much as 2 volts, so to get 5 volts to the motor, you might need to provide 7 volts to the ULN2003.
    Backlash and plastic gears.......
    Well, you can't have everything for bargain basement prices.
    Here is the premium alternative.
    http://www.stepperonline.com/geared-stepper-motor-c-4.html
    edited 2013-03-09 22:44
    Erco said these have 3 degrees of back lash. Im not sure where he got that number, but I would say based tritoniums measurement of 2.5 degrees, somewhere around 3 degrees +/- .5 degrees is a safe assumption.
    I ordered 4 of these a while back, still have not tested them. I want to build a lidar system based around a wiimote camera, and I need an accurate way to adjust the angle of the laser. I had planned on using one of these with a hi res encoder from a printer. The amount of backlash may just kill this idea though, im not sure I would think if one had a good enough encoder for feedback, the dead band could be totally compensated for. Ive also been looking in to brushless hard drive spindels.
    edited 2013-03-10 03:22
    Backlash may become a problems in two ways.
    1. It limits the ability to hold an accurate position. Just consider these motors a bit sloppy.
    2. If you are doing a lot of forward/reverse seeking, it bangs up the gears and these are plastic gears that are not very durable.
    For Peter(pjv), turning small ball valves may do fine. With ball values, I think you can open and shut the valves by always rotating in one direction if you must. That might resolve all the backlash issues.
    I doubt if you are going to get minimal backlash for bargain basement prices. The stuff I posted a link to seems pretty good, but for the absolute least... a direct drive stepper would be the best.
    After all, no gears means no backlash. But you do have to figure out what the holding power of your stepper motor is and how you are going to provide for it.
    edited 2013-03-10 08:23
    erco NEVER said that. Feel free to review post #9.
    edited 2013-03-10 09:36
    So Post #17 is the backlash to Post #15.
    The truth is you should read the specs from some of the quality geared stepper motors and see what their backlash is.... then compare. See my Post #14.
    I am in love with geared stepper motors... especially the ones with planetary gears. These are really useful work horse devices, not junk.
    edited 2013-03-10 12:13
    @Erco, I am so sorry I somehow totally missed that post! I was acually reffering to this one, in another thread about the same motors:
    http://forums.parallax.com/showthread.php/141149-3-Stepper-Motor-amp-Board?p=1163683&viewfull=1#post1163683
  • HannoHanno Posts: 1,130
    edited 2013-03-10 14:17
    These look great! Love the idea of a cheap geared stepper!
    Hanno
    edited 2013-03-10 15:48
    Based on this thread, and the older one, I ordered a batch... Have not had a chance to play with them yet, but they sound like fun.
  • wjsteelewjsteele Posts: 697
    edited 2013-04-16 19:38
    I've discovered that you can easily convert these motors to BiPolar motors by drilling a single hole with a 1/16 drill 3/8 of an inch down from the center red wire in the wiring harness. Don't go too far in, just enough to break the trace in the very center of the pcb board. Then you can use them with any stepper controller. I did have to rearrange the pins in the connector, but that will be a driver specific modification that is really easy to do.
    Bill
    edited 2013-04-17 08:47
    Hi All;
    I tested one from the batch I ordered, and for the price, I like them. At 5 Volts (the rating on them) the torque is not huge; that is you can "just" stall them with your fingers using a really tight squeeze. At 12/15 volts, I'm sure you could not, but then you'd have to be careful not to leave them energized when not stepping. Another benefit, for my application at least, is that when turned off, you can still force a rotation by hand without apparent damage. This will allow me to "over-ride" the setting of my ball valves in case of power failure.
    There is a tiny amount of slop in the gearing.... certainly not an issue for me.
    Cheers,
    Peter (pjv)
  • hnuryhnury Posts: 5
    edited 2013-04-24 10:55
    These cheap geared stepper! looks great.The idea is nice and pracitally applicable.
    I think positioning is very important in this to get the best required results.Thanks for some good stuff.
