ELEV-8 Quadcopter Kit - what is range and flying time?
jigasquid
Those are two of the first things I like to know when exploring brands and designs, and I'm also curious why this info is often either hidden or non-existent?
Thanks.
Thanks.
And just like a dirt bike, YMMV. It depends on the battery you choose, how you fly it, and many other factors. You can get a good minimum by calculating the maxim current per motor, then dividing the battery capacity by 4 times that number. You'll probably fly longer, but at least that will be the minimum.
The flying time will depend upon the battery you choose, the weight of the craft, altitude, temperature and your flying style. I don't know how long it can fly on a 4500mAh battery but I tend to limit flights to about eight minutes. The batteries will last a lot longer if they are not fully depleted. I try to use no more than 80% of a pack's capacity.
As Rich said, you'll likely loose sight of the ELEV-8 before you fly it out of range. I don't think you'll want to fly it more than a few hundred feet away since you really need to be able to tell which way it's pointing in order to fly it. RC airplanes are much easier to fly a longer distances since many of them fly nice and level without any user input. The ELEV-8 requires constant minor corrections to order to keep it where you want it in the air. There are some autopilots that are supposed to be able to keep a quadcopter stable but I haven't used one myself.
I've collected some ELEV-8 links in post #10 of my index.
Here's a video I took using my ELEV-8. It was only a four minute flight, but IMO time slows down when flying a quadcopter. A five minute flight seems like a long time.
