Emic 2 Text-to-Speech / Arduino — Parallax Forums
readrefuse73readrefuse73 Posts: 8
edited 2013-10-07 01:16 in Accessories
I am having trouble "Stoping" playback and unfortunately for me there seems to be very little documentation via a google search.
I downloaded a basic Arduino sketch which worked perfectly.
http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/30016-Emic2-Arduino.zip
The text is sent to the serial port like this:
emicSerial.print('S');
emicSerial.print("This is button number two!");
emicSerial.print('\n');
According to the PDF specifications 'X' is supposed to "Stop playback (while message is playing)".
http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/30016-Emic2TextToSpeech-v1.0.pdf
The PDF also states "Each command must be terminated with a CR or LF."
QUESTIONS:
1. I don't know the Arduino equivalent of "CR" or "LF"
I tried:
emicSerial.print('X');
but this didn't work.
I also tried:
emicSerial.print('\r');
emicSerial.print('\cr');
emicSerial.print('\l');
Any help would be greatly appreciated.
    edited 2013-03-07 09:08
    CR is the byte 13 and LF is the byte 10. In C (like for the Arduino), the string "\r" is a CR. "\n" might be a CR or a LF or a CR and LF depending on the compiler. If that doesn't work for you, you'll need to post your entire program since the problem may be somewhere else.
  • readrefuse73readrefuse73 Posts: 8
    edited 2013-03-07 09:48
    Thanks for the reply!
    I am making the program on a Mac (No I am not a Mac addict).
    #include <SoftwareSerial.h>
    #define rxPin 5    // Serial input (connects to Emic 2 SOUT)
    #define txPin 6    // Serial output (connects to Emic 2 SIN)
    #define ledPin 13  // Most Arduino boards have an on-board LED on this pin
    SoftwareSerial emicSerial =  SoftwareSerial(rxPin, txPin); // set up a new serial port
    const int buttonPin2 = 2;     // the number of the pushbutton pin
    const int buttonPin3 = 3;     // the number of the pushbutton pin
    const int buttonPin4 = 4;     // the number of the pushbutton pin
    // variables will change:
    int buttonState2 = 0;         // variable for reading the pushbutton status
    int buttonState3 = 0;
    int buttonState4 = 0;
    void setup() {
      // define pin modes
      pinMode(ledPin, OUTPUT);
      pinMode(rxPin, INPUT);
      pinMode(txPin, OUTPUT);
      // initialize the LED pin as an output:
      // initialize the pushbutton pin as an input:
      pinMode(buttonPin2, INPUT_PULLUP);
      pinMode(buttonPin3, INPUT_PULLUP);
      pinMode(buttonPin4, INPUT_PULLUP);
      // set the data rate for the SoftwareSerial port
      emicSerial.begin(9600);
      Serial.begin(9600);
      emicSerial.print('\n');             // Send a CR in case the system is already up
      while (emicSerial.read() != ':');   // When the Emic 2 has initialized and is ready, it will send a single ':' character, so wait here until we receive it
      delay(10);                          // Short delay
      emicSerial.flush();                 // Flush the receive buffer
    void loop(){
      buttonState2 = digitalRead(buttonPin2);
      buttonState3 = digitalRead(buttonPin3);
      buttonState4 = digitalRead(buttonPin4);
      if (buttonState2 == LOW) {
         Serial.println("buttone number one");
         emicSerial.print("This is button number one!");
         digitalWrite(ledPin, HIGH);         // Turn on LED while Emic is outputting audio
         while (emicSerial.read() != ':');   // Wait here until the Emic 2 responds with a ":" indicating it's ready to accept the next command
         digitalWrite(ledPin, LOW);
      if (buttonState3 == LOW) {
       Serial.println("Stop button pressed");
        emicSerial.print('X\n');
      if (buttonState4 == LOW) {
        Serial.println("button 4 pressed");
        emicSerial.print("This is button number three. More text will go here.");  // Send the desired string to convert to speech
    edited 2013-03-07 10:10
    The program looks ok as far as I can tell. Exactly what's happening that's wrong?
    edited 2013-03-07 10:47
    Thanks again for the help!
    The desired affect is that when when I pressed my button attached to pin#3 that the text-to-speech will stop.
    Based on the PDF specification sheet (linked above), it states that by sending 'X' + 'CR' or 'LR' The Emic will... "Stop playback (while message is playing)".
    I put a tracer inside the button attached to pin#3 to see when it was pressed but the button isn't even isn't recognized until after text-to-speech has finished.
    It seemed to me that I could interrupt the software serial by sending 'X' but it doesn't seem to work that way. I can't figure out how to stop playback while Emic is speaking.
    edited 2013-03-07 11:15
    Your code is waiting until a ":" is received before it exits from that section of code. What's probably happening is that the Emic2 isn't sending the ":" until it's done speaking so the "X" is ignored. Your code needs to be more complex so that it checks for pushbutton #3 being pressed in the loops that wait for ":" and sends the "X\r" if pressed whether the ":" has come in or not. I think you would need to wait for the ":" afterwards.
    edited 2013-03-07 11:20
    OK. I'll look into this tomorrow.
    It's 8:20 Here in Sweden. Time to get dome diner and get some sleep!
    Thanks very much for your input. Greatly appreciated!
    edited 2013-03-08 02:58
    OK I re-wrote my while statement but still no luck... I can't seem to stop the playback while emic is speaking.
    while (emicSerial.read() != ':'){
      if(buttonState2 == LOW || buttonState3 == LOW || buttonState4 == LOW){
        emicSerial.print('X\r');
         Serial.print("stoped!");
         break;
    just to reiterate. I have three buttons with three different spoken text strings. My intention is to be able to interrupt any button speaking if another button is pressed. Here is all of the code:
    void setup() {
      // define pin modes
      Serial.begin(9600);
    void loop(){
         checking();
         Serial.println("buttone number two");
         checking();
        checking();
    void checking() {
         break;
    edited 2013-03-08 06:10
    buttonStateX never changes in the checking() routine because it's a variable, not the actual state of the pushbutton. Try using digitalRead(...) instead.
    edited 2013-03-08 06:23
    I tried simplifying my objective.
    I tried to start the speech and I to interrupt it after a short delay before it was finished.
    In the PDF documentation is says "X" + "CR" or "LF" will Stop playback while message is playing.
    But I think the specification sheet is wrong?
    I don't think it is possible to actually interrupt it while it is speaking.
    Does anyone one know if it is possible to interrupt Emic While it is speaking?
    void loop(){
         emicSerial.print("This is text-to-speech please feel free to interrupt me before I finish this long speech");
         //delay(100);
         emicSerial.flush();
  • Joe GrandJoe Grand Posts: 70
    edited 2013-03-08 09:52
    Hi there-
    Yes, it is possible to stop or pause the Emic 2 while speaking. This is demonstrated in my Emic 2-to-Elmo code in the Example section on my site:
    http://www.grandideastudio.com/portfolio/emic-2-text-to-speech-module/
    The code is written for the PIC12F675, but you should be able to get a general understanding of how it works. Here's a snippet:
    case PLAYING:  // While the Emic 2 is speaking...
      while (!emic2_check())
        if (!input(SW_SHUFFLE))
          delay_ms(DB_TIME);             // Poor man's debounce
          while (!input(SW_SHUFFLE)); // Wait for button to be released
          printf("Z\n");                // Send Pause command
        else if (!input(SW_STOP))
          while (!input(SW_STOP));     // Wait for button to be released
          printf("X\n");                // Send Stop command
      break;
    The "stop" and "pause" features are also demonstrated at the 3:50 mark of the following video:
    http://www.youtube.com/watch?v=Ot1MgBch0MA
    You shouldn't need a CR after the X (stop) and Z (pause) commands as you can see from the video. But, I use them in my Emic 2-to-Elmo code and it functions fine.
    I don't have much Arduino experience (besides writing the example code for the Emic 2). To test your system, here's a modified version of your code. Note that Emic 2 requires a hard stop (such as a '.') after the text. Also, you had print('X\r') which should use double quotes instead of single.
    void loop(){
       emicSerial.print("This is text-to-speech please feel free to interrupt me before I finish this long speech.");
       delay(500); // let Emic 2 start speaking
       emicSerial.print("X\n");  // Emic 2 should stop
       // end program here
    Have fun!
    Joe
    edited 2013-03-09 04:11
    Thanks very much for your post. This is a nice piece of electronics.
    I tried the code but I can't seem to figure out how to "stop" the play.
    Maybe this is an Arduino problem. I am a student. I don't have a lot of experience with serial communication so I will try and get some help form the faculty on Monday.
    Thanks again for your input.
    edited 2013-03-12 10:27
    Thanks again for everyone's input.
    Joe we tried your code but it didn't work.
    Despite sending the "stop" via the emicSerial it is impossible to interrupt it.
    One of the guys here tried a more sophisticated test. He built a sketch starting the audio durring the set-up.
    A button is coded to "stop" the playback but the button is never registered until after emic finishes speaking.
    Just so you know, we were using an Arduino Uno board. The Arduino sketch was compiled on Linux, Mac and Windows. None of them worked.
    Of course we may have overlooked something at this point it doesn't seem like there is a practical solution.
    [LIST=1]
    [*][COLOR=#000000][COLOR=#339933]#include <SoftwareSerial.h>[/COLOR][/COLOR]
    [*][COLOR=#000000] [/COLOR]
    [*][COLOR=#000000][COLOR=#339933]#define rxPin 5    // Serial input (connects to Emic 2 SOUT)[/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#339933]#define txPin 6    // Serial output (connects to Emic 2 SIN)[/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#339933]#define ledPin 13  // Most Arduino boards have an on-board LED on this pin[/COLOR][/COLOR]
    [*][COLOR=#000000]SoftwareSerial emicSerial [COLOR=#339933]=[/COLOR]  SoftwareSerial[COLOR=#009900]([/COLOR]rxPin[COLOR=#339933],[/COLOR] txPin[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR] [COLOR=#666666][I]// set up a new serial port[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]boolean isSpeaking [COLOR=#339933]=[/COLOR] [B]false[/B][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]String para1 [COLOR=#339933]=[/COLOR] [COLOR=#FF0000]"The boundless blue on every side expanding."[/COLOR][COLOR=#339933];
    [/COLOR] [/COLOR]
    [*][COLOR=#000000][COLOR=#993333]const[/COLOR] [COLOR=#993333]int[/COLOR] buttonPin2 [COLOR=#339933]=[/COLOR] [COLOR=#0000DD]2[/COLOR][COLOR=#339933];[/COLOR]     [COLOR=#666666][I]// the number of the pushbutton pin[/I][/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#993333]const[/COLOR] [COLOR=#993333]int[/COLOR] buttonPin3 [COLOR=#339933]=[/COLOR] [COLOR=#0000DD]3[/COLOR][COLOR=#339933];[/COLOR]     [COLOR=#666666][I]// the number of the pushbutton pin[/I][/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#993333]const[/COLOR] [COLOR=#993333]int[/COLOR] buttonPin4 [COLOR=#339933]=[/COLOR] [COLOR=#0000DD]4[/COLOR][COLOR=#339933];[/COLOR]     [COLOR=#666666][I]// the number of the pushbutton pin[/I][/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#666666][I]// variables will change:[/I][/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#993333]int[/COLOR] buttonState2 [COLOR=#339933]=[/COLOR] [COLOR=#0000DD]0[/COLOR][COLOR=#339933];[/COLOR]         [COLOR=#666666][I]// variable for reading the pushbutton status[/I][/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#993333]int[/COLOR] buttonState3 [COLOR=#339933]=[/COLOR] [COLOR=#0000DD]0[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#993333]int[/COLOR] buttonState4 [COLOR=#339933]=[/COLOR] [COLOR=#0000DD]0[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#993333]void[/COLOR] setup[COLOR=#009900]([/COLOR][COLOR=#009900])[/COLOR] [COLOR=#009900]{[/COLOR][/COLOR]
    [*][COLOR=#000000]  [COLOR=#666666][I]// define pin modes[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]  pinMode[COLOR=#009900]([/COLOR]ledPin[COLOR=#339933],[/COLOR] OUTPUT[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  pinMode[COLOR=#009900]([/COLOR]rxPin[COLOR=#339933],[/COLOR] INPUT[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  pinMode[COLOR=#009900]([/COLOR]txPin[COLOR=#339933],[/COLOR] OUTPUT[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  [COLOR=#666666][I]// initialize the LED pin as an output:[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]  pinMode[COLOR=#009900]([/COLOR]ledPin[COLOR=#339933],[/COLOR] OUTPUT[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR]      [/COLOR]
    [*][COLOR=#000000]  [COLOR=#666666][I]// initialize the pushbutton pin as an input:[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]  pinMode[COLOR=#009900]([/COLOR]buttonPin2[COLOR=#339933],[/COLOR] INPUT_PULLUP[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR]    [/COLOR]
    [*][COLOR=#000000]  pinMode[COLOR=#009900]([/COLOR]buttonPin3[COLOR=#339933],[/COLOR] INPUT_PULLUP[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR]  [/COLOR]
    [*][COLOR=#000000]  pinMode[COLOR=#009900]([/COLOR]buttonPin4[COLOR=#339933],[/COLOR] INPUT_PULLUP[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR]  [/COLOR]
    [*][COLOR=#000000]  [COLOR=#666666][I]// set the data rate for the SoftwareSerial port[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]  emicSerial.[COLOR=#202020]begin[/COLOR][COLOR=#009900]([/COLOR][COLOR=#0000DD]9600[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  Serial.[COLOR=#202020]begin[/COLOR][COLOR=#009900]([/COLOR][COLOR=#0000DD]9600[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  emicSerial.[COLOR=#202020]print[/COLOR][COLOR=#009900]([/COLOR][COLOR=#FF0000]'[COLOR=#000099][B]\n[/B][/COLOR]'[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR]             [COLOR=#666666][I]// Send a CR in case the system is already up[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]  [COLOR=#B1B100]while[/COLOR] [COLOR=#009900]([/COLOR]emicSerial.[COLOR=#202020]read[/COLOR][COLOR=#009900]([/COLOR][COLOR=#009900])[/COLOR] [COLOR=#339933]!=[/COLOR] [COLOR=#FF0000]':'[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR]   [COLOR=#666666][I]// When the Emic 2 has initialized and is ready, it will send a single ':' character, so wait here until we receive it[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]  delay[COLOR=#009900]([/COLOR][COLOR=#0000DD]10[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR]                          [COLOR=#666666][I]// Short delay[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]  emicSerial.[COLOR=#202020]flush[/COLOR][COLOR=#009900]([/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR]   [COLOR=#666666][I]// Flush the receive buffer[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]  emicSerial.[COLOR=#202020]println[/COLOR][COLOR=#009900]([/COLOR][COLOR=#FF0000]"W300"[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  emicSerial.[COLOR=#202020]print[/COLOR][COLOR=#009900]([/COLOR][COLOR=#FF0000]"S"[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  emicSerial.[COLOR=#202020]print[/COLOR][COLOR=#009900]([/COLOR]para1[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  emicSerial.[COLOR=#202020]print[/COLOR][COLOR=#009900]([/COLOR][COLOR=#FF0000]"[COLOR=#000099][B]\n[/B][/COLOR]"[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#009900]}[/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#993333]void[/COLOR] loop[COLOR=#009900]([/COLOR][COLOR=#009900])[/COLOR][COLOR=#009900]{[/COLOR][/COLOR]
    [*][COLOR=#000000]  buttonState2 [COLOR=#339933]=[/COLOR] digitalRead[COLOR=#009900]([/COLOR]buttonPin2[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  buttonState3 [COLOR=#339933]=[/COLOR] digitalRead[COLOR=#009900]([/COLOR]buttonPin3[COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]  [COLOR=#B1B100]if[/COLOR][COLOR=#009900]([/COLOR]buttonState3 [COLOR=#339933]==[/COLOR] LOW[COLOR=#009900])[/COLOR][COLOR=#009900]{[/COLOR][/COLOR]
    [*][COLOR=#000000]    emicSerial.[COLOR=#202020]print[/COLOR][COLOR=#009900]([/COLOR][COLOR=#FF0000]"X"[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000]    Serial.[COLOR=#202020]println[/COLOR][COLOR=#009900]([/COLOR][COLOR=#FF0000]"stopping..."[/COLOR][COLOR=#009900])[/COLOR][COLOR=#339933];[/COLOR][/COLOR]
    [*][COLOR=#000000][COLOR=#666666][I]//    sayThis(para1);[/I][/COLOR][/COLOR]
    [*][COLOR=#000000]  [COLOR=#009900]}[/COLOR][/COLOR]
    [/LIST]
  • Theman8631Theman8631 Posts: 3
    edited 2015-12-25 09:10
    Wewt I found out a method to get X to work, it just has to be passed to the Emic a bit differently
    Check it, http://forums.parallax.com/discussion/150699/emic-arduino-problems-solutions-bohemian-rhapsody
    Take a look at the PrintEmicNoWait function and used in the first section of void loop() shown under //Stop Demo
