Run Basic Stamp 2 without USB connected.
I was under the impression that after I download my code to my Basic Stamp I could run my program code even if I disconnected my USB cable. Is this not the case, if not how do I make it work? Thanks for your help!
Look for obvious problems:
- good battery power?
- batteries / power hooked up correctly?
What is your program?
downloaded your program to the stamp and disconnected your USB.
However:
If you are expecting to see something displayed on your computer screen when using something like DEBUG statements.
When you disconnect your USB you are disconnecting your desktop or laptop computer from your basic stamp system.
Good Luck With Your Endevour.
