120v Relay Flickering on and off very quickly ?!
hi there im new here but know very few about electronics and would like some help
i have a module that remote activate a 120v accesory ( a relay ) and bought a heavy duty 120v voice coil relay so i plugged it and the relay is going on and off on & off very quickly , but when i plug it to the 120v directly there is no problem , if i plug a 120v light bulb at the remote module instead on the relay it lights up just fine ??
im guessing after going true the module the 120v alternating to much ? ...
please help me ... i hope its a easy fix , thank you so much
Drawing too much current from the Stamp can very easily kill the Stamp.
Here's a link to a Nuts & Volts article about using relays with a Stamp.
It would be a lot easier to help if you provided a schematic or diagram of your circuit.
yes sure !
what type of info do you need
the module that i modified originaly is very simple , you plug the module in youre 120v wall plug , and the other end of the module is a house 120v plug but its controled by a rj11 wire and is connected to the main module thats a climate controler
now the module that i want to modify is quite simple
perfectly normal operation of the module
120v going in , rj11 gives signal , 120v is now comming out of the module
120v goin in , rj11 gives no signal , 120v is not comming out
now my project witch is finished at 99% and looks wicked
my project , take the 120v output of the module , and plug it to the heavy duty;s 120v voice coil
very simple , now in theory when the module receives the rj11 signal, 120v comes out of the module , the 120v now goes though the heavy duty relay turning it on and now i can plug what ever i want on the heavy duty relay like a 240v heater ! ( that was the hole ideal
everything is working as planned except when the heavy duty relay gets a signal it doesnt get a steady signal it gets a pulsing signal making it turning on and off veryy quicky ( if i plug my module like this its a fire hazard ..... my relay will end up taking fire because of high current 240v 6a , it will melt the 2 contact point in 2 min like this ... )
there must be a resistor or a capasitor i can put on the line and make it steady again ?
it must be a safe solution because example if its only a matter of a resistor to be added to the heavy duty relay's voice coil and then without me knowing burns and the relay flicker's again then its not good at all ... i rather have a system that if something like the resistor burns then the signal cannot be closed looped then the relay will never open
if i plug the relay direcly on the houses 120v it works perfectly , some how the module transfers the currents slighly alternative to extremely alternative ?
all this just to ask how to make my heavy duty relay work constant grab and not going on and off
btw this module is made and designed to be used as a heater controler 10 amp max at 240V
you put a 10amp or less 120v ( this is Wayyyyy more then what ever the voice coil is pulling ...) heater and it will control the room..... i wanted to put my high power relay to control my 240v heater....
if i plug a light bulb at the end of the module it will light up
my relay acts exactly like a jewelers engraver , turns on and off like 30-60 times a second like hz ?
please help me ! im sooo close to my goal !!
lets take the Second picture
the bottom connecting ,
first on the left white 120v in ,
second middle black 120v in
third on the right black 120v out
fourth top black 120v out
third & fourth is the + & - 120v of the Heavy duty relay
the 2 bottom round hole of the box is the the 240v in & out
hope this helps ??
thank you !!!
It would help to have some sort of schematic to show how things are connected together and to have datasheets for the parts involved. I tried a simple websearch for the number printed on the top of what looks like a relay (# NT90TNAS110CB) and couldn't find anything.
here you will be able to see valuable information
please feel free to ask me any question ( simple ones please, i have very low knolage about electronics , but im very good in house electrical 120v-240v ect )
the web site -- >
http://www.electronicspoint.com/120v-relay-flickering-and-off-very-quickly-t257813.html#post1533601
What at the other end of the line that connects with the RJ11 jack? (This is important to answer. If you're powering it directly from a Basic Stamp you may damage the Stamp.)
What is connected to the load of the "NT90TNAS110CB" relay?
Is the load from the relay "NT90TNAS110CB" used to turn on the other relay?
if i plug a light bulb to the same exact location there will be no problem ... now how to transfer pulsing 120v to stable 120v ? a resistor or something ?
http://www.electronicspoint.com/120v-relay-flickering-and-off-very-quickly-t257813.html#post1533817
module in its original state + modules internal relay up close
when i plug it to my module some how the 120v that comes out of the module makes my relay chatter like crazy
there is no problem with the relay , the relay is working perfecly , the 120v signal coming out of the module is having a pulsing issue
However, I'm still willing to help, because that's just how I am.
Note where I circled on the picture (you can click on it to make it bigger). This relay is rated for 110VDC. That means that when you connect an AC signal to it, it will only be on half the time. That's why your circuit is chattering. The reason that a lamp works okay is because the bulb is a resistive load. It's actually turning on and off well.
EDIT: I see there's a bridge rectifier on the board, so the coil on the NHG is likely to be correct. This is activated by a dry contact, right? Is there a spec sheet for this unit?
So let's back up a moment. What are you using to turn this relay on and off? (I'm assuming that this is happening through the RJ11 connector.)
Here is a link to the NT90T Datasheet.
Also, the contact on the NHG relay is rated at 40A/240vac. Is that not enough the handle whatever load you are looking to use?
the big heavy duty relay was bolted to close back and blocking the voice coil plate....
simply bent the metal a little and it works perrrrrfectly !!!
akward situation hun ? .... lurned it the hard way i guess !
thanks !
