RN-42 Bluetooth Module
I wish to know if this RN-42 Bluetooth module, can we do wireless programming be it PBasic/ Visual Basic or RobotBASIC and also remote control the Boe-Bot using the keyboard?
If yes, then what's the difference between this product compared when using FlashFly Adapter + Xbee modules?
Which is more economical?
Thank you.
Thank you.
You can certainly use the RN-42 Bluetooth module to wirelessly communicate data between a PC program and a Stamp program. I say it that way because the Stamp program is in control. You can write the program so that a "R" makes the BoeBot turn right and a "L" makes the BoeBot turn left. A "F" may make the BoeBot go forwards a little while a "R" may make it go backwards. It all depends on your program.
In terms of your "economical" question ... it depends on what you need. Bluetooth has much more limited range than xBee. Since most PCs now have built-in Bluetooth, you only need one RN-42 module for the BoeBot. If you use xBee, you need a module and adapter for the PC as well. The xBee-like WiFi modules have more range than the standard xBee modules and you only would need one for the BoeBot, but they use more power.
