Propeller Quick diagnostic board
A small project to help me quickly assess the functionally of my many ill treated propeller chips. I believe this is my first time using SMD components.
The code
The code
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
long pin
long low,high
long Stack[16]
OBJ
'screen : "debugger"
PUB startledcog
cognew(Timing,@Stack)
low := 1
high := 27
pin := low
dira[low..high]~~
high++
blinkled
Pub Timing
dira[0]~~
repeat
!outa[0]
waitcnt(clkfreq + cnt)
PUB Blinkled
repeat
dira[pin]~~
repeat until pin == high
!outa[pin]
pin++
waitcnt(clkfreq/15 + cnt)
pin:=low
Here the code:
''Quick-Diagnose-Board''
''An allen Ports leuchten die ''
''Leds nacheiander auf!von P0 bis P29''
CON
VAR
long _vpio 'Stores realtime IO measurements
long pin
long low,high
long Stack[16]
long bit0,bit29
OBJ
'include 1 ViewPort object:
vp : "Conduit" 'transfers data to/from PC
PUB startledcog
vp.config(string("var:io(bits=[pin[0..29],30tx,31rx]),freq(unit=kHz,f=0.001*x,min=1,max=10)"))
vp.config(string("start:mixed"))
vp.monitorina(@_vpio) 'sample the IO port into _vpio
vp.share(@_vpio,@bit29) 'share memory between _vpio and bit29
low := 1
high := 29
pin := low
dira[low..high]~~
high++
blinkled
Pub Timing
dira[0]~~
repeat
!outa[0]
PUB Blinkled
repeat
dira[pin]~~
!outa[pin]
pin++
pin:=low
Many greetings
O. John
