Gadget Gangster Distributed Propeller Platform Modules
varnon
Hey guys,
Is there a list anywhere (with links) of all the old Propeller Platform Modules?
Gadget Gangster leaves the pages up for items that are no longer being sold, but I don't think there is anyway to search for them.
It might be cool to have a collection of those documents. There were a lot of cool modules produced over the years.
Not sure I've seen Nick on in a while. I hope all is well.
http://www.rayslogic.com/Propeller/Products/PPE/PPE.htm
The DNA board is also a Propeller Platform board...
Also the Arduino Shield Adapter for any Propeller Platform board:
http://mghdesigns.com/propeller/gadgetgangster/ppasa.html
As I'm introducing more microcontroller-naive colleagues to the Propeller through the Propeller Platform, I find my self wanting to hoard designs for the modules. So many of them are great designs and are excellent for new learners.
Page 44: Pin Headers - Straight
Page 45: Multimeter
Page 46: Soldering Station
Page 47: Soldering Stand
Page 48: Solder Sucker
Page 49: Desoldering Wick
Page 59: Basic Board Pack
Page 66: Cylon Lights
Page 67: EZ SX Programming Board
Page 68: Xmas Tree Water Spotter
Page 69: LCD Computer Display - Parallel
Page 70: Muzak Visualizer
Page 71: Power Adapter
Page 73: Basic Soldering Kit
Page 77: Remote Control Tester
Page 79: NoiseAxe - MiniSynth
Page 81: Centimani Servo Power Board
Page 82: Naughty Cricket
Page 83: GrooveAxe
Page 84: Analog - Digital Converter
Page 85: Dikes
Page 86: Propeller Designers Pack
Page 87: SX Designers Pack
Page 88: PICaxe Designers Pack
Page 91: Boss Board 2 Pack
Page 94: Extra PICaxe 08M
Page 95: paypaltest
Page 130: Adjustable Power Supply (DC)
Page 133: Xbox Live Headset Amp
Page 135: MemAxe - 8Bit sound effects memory game
Page 136: Quick Adapter Module
Page 138: Programmable Distance Sensor
Page 143: Pocket Instruments
Page 151: Decision Maker 2000
Page 152: Brain Game 1: Stroop Test
Page 153: BOSS EZ-bot
Page 154: Frosty Beverage Timer
Page 155: 5V Ripple Protection Prototype Board
Page 156: Das LED-erman
Page 158: SD Card Adapter
Page 159: ServoBoss
Page 160: PropModule ps_us_sd
Page 161: PropModule 1x1
Page 162: Propeller System Module
Page 163: Morpheus PCB
Page 164: Mem+ PCB
Page 165: Morpheus and Mem+ Board Combo
Page 168: Propeller Platform (Kit)
Page 170: Addtl Shipping Charge
Page 171: Propeller Robot Module
Page 172: Prop Plug (USB)
Page 173: Propeller Designers Pack / Prop Plug Combo
Page 174: Propeller Platform / Prop Plug Combo
Page 175: LCD UI Module
Page 176: Prototyper Module
Page 177: PSM Accessory Board
Page 178: PSM + Accessory Board Combo
Page 187: Highbeamer
Page 193: Multipurpose Audio Amplifier
Page 195: Highbeamer Expansion Kit
Page 198: Propeller Platform (PCB Only)
Page 199: LCD UI Module (PCB Only)
Page 200: Spinning Light Display
Page 201: DMX IO Module
Page 203: Cylon Lights II
Page 204: eBay Auction Timer
Page 205: Quick Touch
Page 206: Simple Servo Tester
Page 207: Quick Player
Page 209: Touchscreen Module
Page 212: simple automatic night ight
Page 213: Acc_Gyro: Accelerometer + Gyro IMU
Page 216: Mono LCD Module
Page 217: Propeller Platform (Assembled)
Page 218: LCD UI (Assembled)
Page 225: Shield Adapter Module
Page 228: Project Board Enclosure
Page 229: Fakenflicker
Page 230: microSD Module
Page 231: Motion Gamepad
Page 232: Touchscreen LCD Module
Page 235: TH1M Digital Temp / Humidity Sensor
Page 236: SIDstick
Page 237: Fakenflicker (PCB Only)
Page 238: Mr. Buzz USB Solar Charger
Page 239: iProp
Page 240: USBThumb - Universal PIC Platform
Page 241: Super GrooveAxe
Page 242: Super GrooveAxe (PCB Only)
Page 243: Mr. Buzz Solar USB Charger (PCB Only)
Page 247: Platform MIDI Module
Page 248: Spinning Light Display (PCB Only)
Page 249: Accel_Gyro (Accelerometer Only)
Page 250: Parts Case
Page 251: Motion Gamepad (PCB Only)
Page 253: Led Candle
Page 254: ProtoPlus Module
Page 255: OctoDriver Module
Page 256: USBCharger
Page 257: Propeller Platform USB
Page 258: Propeller QuickStart
Page 261: SidStick (PCB Only)
Page 262: Tester Module
Page 263: Platform Tester Module (w/ 40 Pogo Pins)
Page 264: Battery Module
Page 265: El Jugador Module
Page 267: ProtoPlus W/ Breadboard and Sockets
Page 276: Audio Power Amplifier With Integrated Variable Gain Preamplifer
Page 277: NES Gamepad
Page 278: El Jugador (PCB Only)
Page 279: El Jugador With Propeller Platform
Page 280: RED Burning Laser Diode Driver
Page 281: Propeller Platform SD
Page 282: Blue LED Matrix Display
Page 283: TermBoard Module
Page 284: Pixter X Platform Module
Page 285: OctoDriver (PCB Only)
Page 286: PropNET Module
Page 289: USBThumb Propeller Programmer
Page 290: UsbThumbImu
Page 291: Platform Universal Adapter Module
Page 292: Propeller Platform SD w/ RTC
Page 294: Quick Servo/Sensor
Page 295: Quick Proto
Page 296: Pin Headers - Right Angle
Page 297: Pin Sockets
Page 298: Analog Joystick
Page 299: Tactile Switch
Page 300: Slide Switch
Page 301: Terminal Block
Page 303: Trickster
Page 304: DIP Socket - 8 Pin
Page 305: DIP Socket - 40 Pin
Page 306: Pin Sockets - Machined Pin
Page 307: NES Controller Socket
Page 308: Voltage Regulator - 5V
Page 309: Voltage Regulator - 3.3v
Page 310: UsbThumbImu (W/ Gyro)
Page 312: 6Mhz Crystal
Page 313: 5Mhz Crystal
Page 314: 25Mhz Crystal
Page 315: 32kHz Watch Crystal
Page 316: 16MHz Resonator
Page 317: 8MHz Resonator
Page 318: LED - Red
Page 319: LED - Green
Page 320: LED - Blue
Page 321: LED - Bicolor R/G
Page 322: 3 Axis Digital Accelerometer
Page 323: SerPlug
Page 324: Switchboard Module
Page 325: Command Pad Module
Page 326: RCA (Phono) Jack
Page 327: Shunt Jumper
Page 328: Battery Box - 3xAA
Page 329: Battery Box - 4xAA
Page 330: Battery - 9v
Page 331: Battery - 1xAAA
Page 332: Command Pad (PCB Only)
Page 333: TinyTwoWire Module
Page 334: Propeller Platform USB Bare PCB
Page 340: Digital Interface Pack
Page 341: Servo Controller Module
Page 346: VGA AV Module
Page 349: E-Net Module
Page 350: Propeller
Page 351: 32KB EEPROM
Page 352: 64KB EEPROM
Page 353: 555 Timer
Page 354: H-Bridge
Page 355: Servo Player Module
Page 356: DC Motor Driver
Page 357: Opa! Amp
Page 358: PowerTwig
Page 359: SDRAM Module
Page 360: Replica 1 TE SD & Sound Upgrade Board
Page 361: Ping))) Reflector
Page 362: SDRAM + TV Module
Page 363: SDRAM + VGA Module
Page 367: Acc_Gyro_6DOF: 6-axis IMU
Page 368: Touchscreen 3.5 Module
Page 369: Propeller Relay Card
Page 376: 444-AVXB Robot Module
Page 377: Propeller Platform Enclosure
Page 378: Video Fireplace
Page 379: Toilet Buddy
Page 380: RC Animator
Page 381: Servo Sensor Module
Page 382: GFX Module
Page 383: 10k Resistor
Page 384: 1.1k Resistor
Page 385: 4.7k Resistor
Page 386: 0.1uF Capacitor
Page 387: 0.001uF Capacitor
Page 388: 220uF Capacitor
Page 389: IR LED
Page 390: Rectifier, 1N4001
Page 391: Diode, 1N4148
Page 392: 40 Pin, 2 Row Header
Page 393: PNP Transistor
Page 394: NPN Transistor
Page 395: Large Tactile Switch
Page 396: Spacer and Screw
Page 397: 9P DIP Switch
Page 398: Nunchuck Controller
Page 400: Stackable Headers - 10 Pin
Page 401: Quick Terminal
Page 402: Quick VGA+
Page 403: 32k SRAM
Page 404: Smorgasboard PCB
Page 405: Pocket Mini Computer
Page 407: microSD Add-On
Page 408: 1 Amp USB Power Supply
Page 409: USB Cable, 3 Feet
Page 410: Classic Pro Controller
Page 411: USB Cable, 15 Feet
Page 412: Car Kracker 3
Page 413: Car Kracker 3 + DSP
Page 414: CHARGING BYE-CYCLE
Page 415: CHARGING BYE-CYCLE
I assume (hope) you had a quick way of producing that list.
I downloaded a bunch of the webpages and files. So many of these are great educational projects.
There were quite a few that I had not seen before. I guess they were before my time.
Does anyone have the source code and firmware for SIDstick? I checked the page on the wayback machine and found that only the link to the source code was dead.
https://web.archive.org/web/20100624225134/http://gadgetgangster.com/find-a-project/56?projectnum=236
I posted a zip file to your other thread about this topic
