Ben Krasnow uses a Propeller — Parallax Forums
Roy ElthamRoy Eltham Posts: 3,000
edited 2013-02-26 15:34 in Propeller 1
Cool stuff!
  • jazzedjazzed Posts: 11,803
    edited 2013-02-26 00:08
    Propeller is a nice fit for the project. Kind of a Propeller project poster child, no?
    edited 2013-02-26 01:07
    I like the walk through on his hacking process it's a good insight on reverse engineering. Seriously,though, "no interrupts"??? How can it work?? :0)
    edited 2013-02-26 01:12
    That is one of the best advertisements for the Propleller I have ever seen. Very cool. The Prop is a perfect fit there.
    I hope he follows that up with the video display of the measurements.
  • doggiedocdoggiedoc Posts: 2,243
    edited 2013-02-26 03:31
    Cool! Hope to see the followup video.
    edited 2013-02-26 06:10
    More importantly, is he a member here?
  • Mike GMike G Posts: 2,702
    edited 2013-02-26 06:22
    Maybe 20 lines of code?
    edited 2013-02-26 06:27
    That was a great video, thanks for posting it.
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2013-02-26 10:13
    Very cool hack!!!!
    Don't get me wrong, he did it nicely in assembler.
    For me, that would be a stretch right now. I 'm more of a hardware guy.
    That bit string also could be captured with a 32 bit hardware shift register.
    There are 40 clock pulses corresponding to 40 data bits. The first 8 have no value, presumably.
    After the 3mS data string is captured the data could be shifted into the prop at a slower rate.
    The shift pin on the shift register is ORed with the clock from the AtoD an the Prop.
    There should be enough time to do this, and other things, in 130mS at 7.5 samples/S and do it in spin.
    If that's to fast one could read every other sample.
    (Woo, Roy Eltham commented on a similar technique in software. I should have read thoes comments before this posting. Like minds huh.)
    BTW, this device looks fairly easy to work with, their not always this simple.
    Duane J
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-02-26 10:24
    Here is the 24bit a/d
    http://www.mouser.com/ProductDetail/Cirrus-Logic/CS5530-ISZ/?qs=sGAEpiMZZMuYaq4aOfOV%252bAj8IxaLNHFA
    I would make the prop a SPI master and make my own readings in-between the C51 does its, as there is plenty of time.
    Just wait wait for CS to go high and then turn that Prop pin around and pull CS low to start my own SPI sequence.
    edited 2013-02-26 10:26
    tonyp12 wrote: »
    Nice idea!
    That ADC is attractive but costly. Seems like it was over-spec'd.
    Maybe you can design a high speed SERDES in Verilog to share with Chip for the next Propeller incarnation.
  • KC_RobKC_Rob Posts: 465
    edited 2013-02-26 11:03
    Yes, cool! The Prop gets some really good props here. :)
    Wow, I can't believe how ugly that assembled PCB is.
    edited 2013-02-26 11:07
    I can't believe they used a 24 bit A/D. Do they really expect to weigh anything to one part in 16 million or so with that device?
    edited 2013-02-26 11:18
    Heater. wrote: »
    Could there be enough bottom end noise that they throw out the lower 8 bits and scale the middle 16? Not so much for accuracy but because of a cheaper/noisier sensor? (totally guessing if it's not obvious!)
    edited 2013-02-26 11:28
    I should add, too, that this is something of an advertisement for Spin/PASM as well. He seemed quite content to stay with that combination while tackling the problem at hand.
    edited 2013-02-26 13:54
    He had a prerequisite that he wanted to not "destroy" the scale in the process. So it could still work on it's own.
    I chatted with him today about code, and he hoped that most of what the overall project needs could be done with Spin and only a little PASM (since he wasn't very strong in PASM). I mentioned propgcc (which he wasn't aware of until I mentioned it) and he thought that was a cool option, but asked about mixing that with pasm and spin (which I explain a bit about).
    We'll see what he decides on in the next video I guess.
    Roy
    edited 2013-02-26 14:16
    Roy Eltham wrote: »
    I'll be very interested to see what he ends up with.
  • LawsonLawson Posts: 870
    edited 2013-02-26 14:31
    Heater. wrote: »
    First, he mentions that the scale reads to mili-grams, so it's rather precise. Second a 24-bit ADC like what's used in the scale can be connected directly to a strain-gauge bridge and still give good resolution. Direct connection avoids the cost, electrical noise, and drift of using an external amplifier.
    Interesting that the board looks hand-soldered. This scale must be a pretty low volume item.
    Lawson
    edited 2013-02-26 15:22
    I often see that in Chines items, they often don't do a complete redesign when it comes to adding some new smt/modern ICs.
    I guess they don't want to mess with what worked in 80' and labor cost is still low to have stuff handsolderd.
    The scale measures up to 100 grams, in 0.002 gram steps. It costs about $145 on Amazon.com.
