Min Voltage for LiPo
I've been running RC lipos on my BOE bot and one of them got really puffy. So puffy I put it in a LiPo bag. I would imagine the battery would have a specific recommended voltage but I cannot find it. I'm used to having an ESC that shuts it off but on the robot it's just plugged into Vin and I guess I got careless.
The pack is 11.1v 3S 1800 mAh 30c/60c burst. To avoid this in the future I got a little battery minder that goes off when any cell gets to a preset voltage. The problem is, what preset voltage per cell?
Let's talk about voltage under load, not resting voltage.
Thank you.
- My airplane's ESC is set to 70% of turn on voltage so 12.6v to 8.82v = 2.94v per cell
- The general rule I've been using is 3v per cell
- Most of the RC forums say 3.7v per cell
Thank you.
Parallax should make a LiPo power supply board that works with larger off the shelf LiPo batteries for robots, that would be really cool. Drop the 12.6v down to 7.2v, and 5v rails, maybe an AD per cell with I2C for voltage monitoring. Batteries always seem to be an issue once you get past something the size of a BOE Bot. I'd definitely be using 3S 5000mAh on a Stingray in the near future.
I know a sure fire way to shorten the battery life on my micro helicopter batteries is to land and take off again after the helicopter has started losing power (a signal the battery is getting low). Draining the last bit of charge from the battery is really hard on it.
You can drop the voltage of LiPo packs pretty easily and inexpensively with these cheap ebay switching regulators. (You might need one for each motor to use with a Stingray.)
BTW, If you can find the LiPo you want at the HobbyKing USA warehouse, the shipping costs much less and it arrives much soon than from China.
I guess 3.5v makes sense, given the load is going to vary and 3.5v under a light load could easily drop lower under a heavier load. For the robot it's not like I have to land or anything though. I think for primarily indoor use I'll go lower, 3.2v. I can see for aircraft 3.5v would make more sense, especially depending on what and how you fly. I guess that is why so many people say so many different voltages. Since nobody really knows how the pack is being abused err... used, it's better to just go with a higher cut off.
The microcopter I have is a Blade MSRx and it will toast a pack if you let it fly to the ESC min. I just measured that to be 3.0v by hooking the copter up to my bench PSU. The pack goes bad after around 50 cycles if you don't stop flying before the ESC cut off. Lame, but re-enforces the don't hit 3v rule. Those are 1S 3.7v 30mAh E-Flite brand. All this time I was trusting the ESC on it to make the right decision. At least it uses a set reference and not 70% of turn on voltage, that is just a horrible idea...
I get SkyLipo brand packs, from US based places. Every time I order from HobbyKing, even if it is in China the shipping is still pretty good. I had my Skywalker in 10 business days with the cheapest shipping, I was pretty amazed people said I'd be waiting a month haha.
I have two brand new 3300mAh packs, I'm going to run one down to 3.1v and one down to 3.5v and maybe in six months see how big of a difference there is.
* 3.5 or 3.6 volts as a first limit (10,7 volts for 3S lipos) : the lipoAlarm beeps
* 3,3 volts : land without delay
(If you dont have one , buy a lipoalarm : its cheap about 2 or 3 $ and usefull with leds giving the voltage : total and per cell , and one LED blinking and a loud beep for alarm. Connect it to the balancer connector of the lipo and you are safe)
If a lipo gets puffy don't use it. May get in fire.
Jean Paul
Agreed. Erco just posted a link to a dual voltage meter / alarm.
I've been playing around with this and found that the cut off voltage depends a lot on how much current you consume and the condition of the battery.
If your battery is in bad shape, it can drop as much as .5v under load, in good shape close to .1v. I have some LiPos in bad shape and did a lot of flying (with my big rc plane this weekend) and fully charged the alarm would instantly go off at full throttle. The voltage depends a lot on the condition of the pack.
I'm sure this is pretty much common sense to electronics savvy people, however I have never given it this much thought.
It is all about chemical differences in the ions involved. BTW, Lithium ION cells are the rechargeable lithium cells.
I have strong doubts that people that refer to LiPO really know which chemistry they really are using. Many retailers are confused or are just making claims that they are providing the type that is most popular at the moment.
In general, there are Lithium ion cells that provide a steady 3.2 volts per cell and cells that provide a steady 3.7 volts per cell. They have different cutoffs and the 3.2 volt cells are always lower settings than the 3.7 cells.
http://en.wikipedia.org/wiki/Lithium-ion_battery
Having LiFePO4 as a possible chemistry could confuse the issue. The PO in LiFePO4 are the symbols for the elements Phosphorous and Oxygen. The "Po" in LiPo is short for "polymer".
I''ve always seen "LiPo" used to describe Lithium Polymer cells commonly used in RC vehicles. The voltage cutoff levels suggested by most posters in this thread have pertained to this type of battery.
Just look here for a list of all sorts of different voltages ===>http://en.wikipedia.org/wiki/Lithium_battery
Set your cut off higher 3.2 volts or so.
That is likely your problem as the LiFePO4 is a 3.2 volts nominal output and tolerates a much lower cutoff before failure.
Yes LiPO and LiFePO4 are easily confused. The rc users are likely to explain how to avoid this minefield of confusion. But the nominal voltage labled on the the battery should be the best clue.
http://en.wikipedia.org/wiki/Lithium_polymer_battery
http://www.rcgroups.com/forums/showthread.php?t=209187
