Extra \r in putc?
I have a simple program that should output six characters per iteration: a \r, \n, and 4 bytes from an int. However, when I run the program I get the following output (in hex):
Notice the double 0d in the output, even though the program only has one putc(0xD). This 0d is repeated throughout, so I know it's not a random event from outputing the four bytes from the int. I've looked at the assembly file, and it's has six calls to #_fputc, as expected.
There is a second problem as well. I've attached a screenshot of a logic analyzer capture of a packet of data, and the bytes are out of order. Notice how the \r\r\n is at the end of the packet, instead of at the beginning as expected. Again, I looked at the assembly code and it's as expected: the waitcnt is at the end of the packet, and the \r\n is at the beginning.
Any ideas on what is going on with this curious behavior?
Compiled with:
Notes:
-I tried it with printf as well, and got the same results.
-I can "fix" the first problem by removing the first putc line, but the mystery character still appears.
-The same thing happens in -Os and -mcmm modes.
Thanks for any and all feedback.
... 00000000: ec 2e 00 00 0d 0d 0a d5 32 00 00 0d 0d 0a be 36 00000010: 00 00 0d 0d 0a a7 3a 00 00 0d 0d 0a 90 3e 00 00 00000020: 0d 0d 0a 79 42 00 00 0d 0d 0a 62 46 00 00 0d 0d 00000030: 0a 4b 4a 00 00 0d 0d 0a 34 4e 00 00 0d 0d 0a 1d ...
#include <propeller.h>
#include <stdio.h>
int main(void){
for(int i = 0;;i+=1001){
putc(0xD, stdout);
putc(0xA, stdout);
putc(((unsigned)(i & 0xFF) ) >> 0, stdout);
putc(((unsigned)(i & 0xFF00) ) >> 8, stdout);
putc(((unsigned)(i & 0xFF0000) ) >> 16, stdout);
putc(((unsigned)(i & 0xFF000000)) >> 24, stdout);
waitcnt(CLKFREQ/2 + CNT);
Compiled with:
propeller-elf-g++ -mlmm -O0 -save-temps simple_output.cpp propeller-load -r -e a.out
Notes:
