Smelly Oily Li-Ions
Just received four AA-sized 14500 cells from Ebay China and two of them are oozing smelly oil. That's gotta be a bad thing. I wiped them down thoroughly and yet the oil returned, so I'll toss without even trying to use them. I've ordered dozens of Li-Ion cells from China and this is the first leakage I've seen. The smell is very pungent, so if you have a leak, you'll know it quickly.
For shipping, they were unusually well-packed in thick bubble wrap, so they didn't get damaged in transit. Curiously, each cell was individually wrapped in a poly bag. Maybe the seller knew some cells leaked...
Dissolve some salt in cold water and place in a container outside, leave the cells for several weeks - the idea is the conductive water discharges the cells completely and
the water slowly infiltrates the cells and the lithium goes into aqueous solution. I've seen this recommended specifically for bulging cells which are by definition
in a dangerous state.
However LiIon is more sealed so I suspect some other procedure is appropriate. Putting in a sand-filled fire bucket outdoors is perhaps a paranoidly
safe option in the absence of other data.
The funny thing was, only after I looked at the photos did I notice that these are bogus labels on the batteries. They aren't UltraFire batteries. The label reads UitraFlrc
BTW, seller is mxqtech/banggood, so avoid ! http://www.ebay.com/itm/400387180338
Is that rust that I see? I could understand a pressure release in transit making them oiling, but rusty?
Bogus labels? Avoid like the plague. I have some 2N3055s with the Motorola label faked with a generic M and 90% out. It seems some jurisdictions consider these to be a unique brand and not subject to copyright infrigement, just another brand. But you are always getting junk. They won't hold up if they will work at all.
Also, I have a quetion about the batteries. About how long can I expect my BS2 Boe Bot to run with the two servos and maybe a ping and ir sensor operating? I do not need an exact figure, I just want to get a general idea.
You might use an ADC with a zener reference voltage on the microcontroller to do an orderly shutdown.
In an attempt to give my Popsicle stick robot a bit of extra oomph, I tried using a two cell LiPo to power it. I think it was less than two seconds later when one of the servos started smoking. I'd be very wary about using two 3.7V (which can be over 4.2V when fully charged) Li batteries with a servo. I know some servos state they can be safely powered with a two cell LiPo but I think those are the exception I believe the normal limit is around 6V.
These switching regulators have been working great for me. Besides dropping the voltage to a safe level for servos it also gives the servos a consistent voltage so they behave predictably (good for robot figure eights).
I've been trying to measure the capacity of one of the cells (18650) NWCCTV just linked to. I first charged it with the cheap ebay charger and a few days later hooked it up to my (HeliMax? (a nice one)) charger and put it in discharge mode. I initially set the cutoff to 3.5V. At 3.5V cutoff it stopped discharging after 17 seconds with a capacity of 10mAh.
After this first discharge, I charged it with my high end charger at 2.0A. The charge cycle was longer than the discharge cycle but not by much. The batter charged for 1 minute 19 seconds with a capacity of 6mAh.
I think the automatic cutoff chip must have been activated because I think the battery is starting to show signs of behaving.
I changed the discharge cutoff to 3.0V and discharged the battery again. This time the battery discharged time was 12:34 (minutes:seconds) with a capacity of 481. What gives me hope about these batteries is the initial voltage for the just mentioned discharge was about 3.5V. The voltage at the end of the discharge was about 3.8V.
I'm hoping the automatic cutoff chip has reset. Currently the battery is charging again and it has been going for over 15 minutes. I'm hoping I can figure out a reliable way to reset the cutoff chip whenever it trips. I'd also like a reliable way of detecting when the cutoff chip activates.
I just checked the charger, it has been charging the battery for 27 minutes and it has delivered 306mAh of power to the battery. I don't think I'll have a good indication of the battery's capacity until I perform another discharge since the protection chip may have previously keep the battery from full discharging.
I'll edit this post when I complete the current charge/discharge cycle.
All I have are the cheap eBay Li-Ion chargers like http://www.ebay.com/itm/New-Universal-Battery-Charger-AA-AAA-18650-16340-CR123A-Smart-Charger-Hot-EA-/360604411155?pt=Battery_Chargers&hash=item53f5b2a513 They just have a red & green LED, it's not clear if they are "done" charging when the LED turns green, or if the charger has changed modes (CC to CV?) and they still need to trickle up for a while.
I'll be curious to find out how much extra capacity you get using your expensive charger. Wouldn't it be funny if the cheapie was as good as or superior...!
Edit: See http://en.wikipedia.org/wiki/Li-ion and read "History". I think it's funny that one of the developers of Li-Ion technology was named John "Goodenough". With that name, why would anyone strive for excellence?
