Hackspark! - 32cm x 16cm, USB-controlled Full-Color (RGB) Led Matrix Video Panel — Parallax Forums
tdg8934tdg8934 Posts: 126
edited 2013-02-20 08:10 in Propeller 1
Has anyone seen these USB (also has versions controllable via a micro controller like the Propeller perhaps) 32x16 RGB LED Matrix displays?
http://hackspark.fr/en/32cm-x-16cm-usb-controlled-full-color-rgb-led-matrix-video-panel.html
They are a bit expensive at $150 USD + shipping but can play video, pictures, etc. They have much larger sizes too at a premium cost.
http://www.youtube.com/watch?v=YizwWr0yLsI
http://www.youtube.com/watch?NR=1&v=URYyJcIubGU&feature=endscreen
    edited 2013-02-20 07:51
    I've been playing/working with some $6 8x8 arrays. I've had a PCB made and I'm working on code in hopes of driving a bunch (16?) with a single Propelller.
    I doubt I'll be able to get the LEDs do what the Hackspark does, but it should be less expensive.
    While I hope to be able to make a similar sized array for less money, $150 isn't a bad price for what that can do.
  • RaymanRayman Posts: 14,826
    edited 2013-02-20 08:06
    Your Adafruit setup can do all this and more and is less expensive, right?
    Or, do you like that it is controlled by a computer over USB connection?
    Seems that we could make some PC software to do the same thing...
  • tdg8934tdg8934 Posts: 126
    edited 2013-02-20 08:09
    After chatting with Jonathan from HackSpark! yesterday he said they have boards like the Adafruit in 6 pitch? size and also 10 pitch? size (LEDs spead apart more).
    http://adafruit.com/products/420
    Tim
    They have basically an Adafruit "like" board with a built in controller board (FPGA?) into the LED board itself from what I understand.
    Tim
