Worst Linux Computer Ever. — Parallax Forums
Martin_HMartin_H Posts: 4,051
edited 2013-02-20 11:02 in General Discussion
This is a year old now, so it might have been posted before. But if not there's hope for Propeller heads who want to run Linux on the Propeller chip.
http://hackaday.com/2012/03/28/building-the-worst-linux-pc-ever/
So it takes hours to boot and has an effective clock speed is about 6.5 kilohertz.
    edited 2013-02-20 07:24
    Is it a contest to make the worst?
    I have one virgin BS1 Project board left, looking for the right app...
  • doggiedocdoggiedoc Posts: 2,254
    edited 2013-02-20 07:33
    I could dig out my old Apple II.
  • jazzedjazzed Posts: 11,803
    edited 2013-02-20 07:46
    So much left to do for wasting what's left of my little time ....
    edited 2013-02-20 07:59
    Linux is based on Unix and has its roots in a multi-user environment. There is a heck of a lot of features that a Propeller doesn't need. Even the file system is more than the majority of Propeller applications require.
    While I really love Linux, and C is helpful for the Propeller; I find that not only is Linux not necessary, Forth is a very fun and interesting OS or OS-like bit of software for the Propeller.
    IMHO, Fitting Linux on a slow tiny system is more of a demonstration in not knowing what software is appropriate for a given hardware platform than it is a proof of Linux functionality.
  • Mark_TMark_T Posts: 1,981
    edited 2013-02-20 08:09
    Its only a matter of time before someone does this in Minecraft!
    edited 2013-02-20 08:17
    There was a thread on this before, but I couldn't locate it with a quick search. I did some work on a Linux-like OS called spinix. It works OK, but the 32K hub RAM is a limiting factor. I'm looking forward to porting it to the P2 when that is available. spinix should be quite useable on the P2. The limiting factor will then be the 8 cogs, but that can be extended by doing multi-tasking on each cog.
    As far as using Forth for an OS, that's a really bad idea. The user interface is horrible and the traditional Forth file system is even worse.
  • AleAle Posts: 2,363
    I think that the simulation boots linux faster that it takes to write/read all the threads about porting linux to the propeller. Such an emulator wuld be much faster on the propeller, though :)
