SUSE 12.2 SimpleIDE
I set up a system that is running SUSE 12.2, and installed SimpleIDE, successfully. The problem that I am having is creating/storing .side files to an external hard drive that is mounted. When I open the SimpleIDE Properties, and browse the Workplace Folder, the external drive does not appear anywhere. What am I missing here?
Ray
Ray
I just started up my Suse 12 x86_64 VM.
I see my "HP Pocket Media" drive in the Open File and Open Project dialogs with the SimpleIDE version 0.8.5.
Ray
No, all I get is the root volume. Even when I use the "Look In", all it shows me is what is available on the root volume. When I insert a USB thumb drive, that does not appear as a choice in SimpleIDE, either. Wonder if there is a setting that I missed when I installed?
Ray
Beside that your removable devices should show up in /media when mounted. If you go to the root directory and navigate into /media what do you see?
In the bin folder (relative to the folder where the simpleide script lives) there were two Qt libraries which shadow the native Qt libraries in my system. I removed them since they lead to a situation where my desktop settings for the appearance were completely ignored. I just put them back now to be sure and then I see the file dialog you see, removing them again leads to what I am used to, to have the application in the style which my destop environment defines.
Hope that helps.
Ray
Another problem that I am noticing is access to the windows computers that are on my network. I have noticed this problem with Ubuntu, Fedora, and now OPENSuse. Anybody else having the same problem? Yes, I have Samba client associated and running.
Ray
Ray
You will enjoy KDE. It is beautiful, functional, and rock solid under SUSE. (KDE on Fedora seems a little buggy to me).
Now, setting up a network printer is not for a novice to try, Windows 8 is a delight in this regard. I tried the print option within SimpleIDE, and it works as expected. Still wondering why I am not seeing a 'Places' in my setup?
Ray
I loaded and tested the following: Ubuntu 12.04 LTS, Fedora 18, Windows 8, and OPENSuse 12.2 gnome/KDE. My list goes from worst to best OS handling of the equipment described above. Although, now I have to move OPENSuse back a notch and move Windows 8 to the best for the system that I am using. As a general observation each one of the OS's had a problem with the USB3.0 port(s), but Windows 8 seemed to do the best job.
I am probably going to keep the OPENSuse 12.2 KDE on the computer and the SIIG HUB plugged into the second USB3.0 port and use the 4 USB2.0 ports. If I need some more HD expansion, the MB does have an eSATA port that I could use.
This is the first time that I have used a Gigabyte product, normally I use Asus, so I hope this is not a MB problem, although, as I mentioned, the Windows 8 seemed to have least amount of problems with my setup. I had noticed that OPENSuse 12.3 will be available in about a month, maybe with the new release all the problems will disappear. Hopefully the NEW SimpleIDE will be available by then.
Ray
Ray
Sounds like you're making some good progress. Ubuntu uses apt-get instead of yast. There is also a software utility in the system tools.
--Steve
