A question about biasing phototransistors (the kind with 3 leads). — Parallax Forums
ElectricAyeElectricAye Posts: 4,561
edited 2013-02-16 11:56 in General Discussion
I'm baffled by this. There are some phototransistors that have leads to their bases. These base leads can be used to bias the phototransistors, but this biasing doesn't work the way I would guess it should. For example, the webpage that provides the diagram below, says this: "High values of base resistor Rb prevent low levels of light from raising the current levels in the collector emitter circuit and in this way ensuring a more reliable digital output. All other aspects of the circuit function remain the same."
To me (armed with my pathetically limited understanding of transistors), it should be the other way around. I would think that a high value for Rb would make the phototransistor more sensitive to light, not less sensitive to light. If Rb were infinite (an open circuit), I would think low levels of light would make it work. If Rb = 0, I would think that no amount of light would ever get the phototransistor to work since all the current at the base would be shorted to ground. What's wrong with my notion of this?
http://www.radio-electronics.com/info/data/semicond/phototransistor/photo-transistor-circuits-symbols.php
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2013-02-15 21:18
    Hi Eye;
    I think you have it correct.
    That writeup is a misprint.
    Duane J
    edited 2013-02-15 21:38
    Hi Eye;
    Duane J
    +1
    I've built numerous ptx circuits where the base is left disconnected, light on the junction does all the biasing. Essentially infinite resistance, as you noted. Adding any resistance would desensitize the ptx IMO.
  • jmgjmg Posts: 15,193
    edited 2013-02-15 22:38
    Note they merely say 'High values', they do not say what happens as that high value changes.
    Low values prevent it from working at all, so the 'high value' is intended to alert designers "to approach this problem from above".
    edited 2013-02-16 07:10
    Thanks, Duane. That's a relief! I was worried about this all night.
    And +10 to you (gain factor here) for helping relieve my anxieties about this.
    jmg wrote: »
    ...so the 'high value' is intended to alert designers "to approach this problem from above".
    Ah, that explains why I've read this sort of thing in more than one place. Thanks, jmg.
    edited 2013-02-16 07:22
    Hi jmg;
    jmg wrote: »
    That makes sense.
    Poor choice of words in the description.
    The photo-current in photo transistors is usually in the pA to low uA range.
    So, the resisters are relatively high values of resistance, often in the 100KO to MO range.
    Higher values increase sensitivity as they bled of less photo-current although high switching speed is slowed.
    Lower values reduce sensitivity but tend to increase switching speed.
    Duane J
    edited 2013-02-16 08:13
    Lower values reduce sensitivity but tend to increase switching speed....
    That's perfect. That's exactly what I was hoping for. Thanks again!
    It is not so much a misprint as an incomplete or poor explanation of the purpose of that resistor. It is used to decrease the sensitivity of the phototransistor so that low levels of light will not trigger a digital circuit. I had to use such a resistor on a led/phototransistor circuit that monitored the fore pump on a high vacuum system. Since the pump pulley was exposed to room light and the phototransistor was detecting the low light levels caused by the pulley spokes, the stray light was enough to cause the spokes to be missed without the base resistor.
