Hide Cursor on Parallax 2x16 Serial LCD (Backlit)
Nautiluscl
Hi!
I want to hide the cursor ( _ ) in my LCD ( #27977 Parallax 2x16 Serial LCD (Backlit) REV F) i send the "4" char but dont work
Any help?
' {$STAMP BS2} ' {$PBASIC 2.5} TxPin CON 0 n9600 CON 84 HIGH TxPin ' Set serial pin port high PAUSE 100 ' Pause to initialize SEROUT TxPin, n9600, [12, 17] ' Clear, turn on backlight PAUSE 100 SEROUT TxPin, n9600, [12, 4] ' Hide Cursor? SEROUT TxPin, n9600, ["Test"] ' Print text, line feed
Any help?
Hi, just noticed it was your first post, welcome.
4? That won't work.
Here are the commands from the manual
Try sending 22, that was the only way I ever used mine and it always worked.
Also, when you send a 12 command you should follow with a short 5 msec pause every time or there may be problems.
Good luck.
