Setting a single bit in Spin — Parallax Forums
RumpleRumple Posts: 38
edited 2013-02-16 12:19 in Propeller 1
I can't believe I've never tried to do this before. What's the best way to set and reset a single bit of a long in Spin? I've always assumed it was "someregister[0]~~ ",since "outa[0]~~" works, but apparently that's not it.
Something with "|<" in it maybe?
    edited 2013-02-14 09:47
    This will set a single bit:
    singleBitMask := |< pinNumber
    To "or" one mask to another (oring enableMask on to activeMask)
    activeMask |= enableMask
    To turn off these same bits (same function as "andn" in PASM):
    activeMask &= !enableMask
    Thanks to my fellow forum members for this useful stuff.
  • David CarrierDavid Carrier Posts: 294
    edited 2013-02-14 11:05
    To set a bit use this:
    variable |= |< bit
    It will decode the bit, which creates a value with only that bit high, then OR the result into the variable.
    To clear a bit use this:
    variable &= ! |< bit
    It will decode the bit, which creates a value with only that bit high, invert it, which makes all bits high except the one you are clearing, then AND the result into the variable, effectively clearing that bit within the variable.
    — David Carrier
    Parallax Inc.
  • RaymanRayman Posts: 16,271
    edited 2013-02-14 11:58
    I like to use the unused INB, OUTB and DIRB registers for this...
    Just copy the long you want to work with to DIRB and then Spin will let you do dirb[SomeBit]:=1 and things like that...
  • RumpleRumple Posts: 38
    edited 2013-02-14 15:13
    Nailed it. Thanks for your help guys.
    Also, that's brilliant, Rayman.
  • HarpritHarprit Posts: 539
    edited 2013-02-16 06:00
    How about reading one bit,or a range with compact code
    H
  • JonnyMacJonnyMac Posts: 9,796
    edited 2013-02-16 07:48
    bitval := (testval >> bitpos) & %1
    If you want to read a group, set bitpos to the LSB value and change the & %1 to something that fits your group; for a nibble it would be & %1111.
    edited 2013-02-16 10:12
    reading a range is really easy using, e.g., INB too...
    For example, you can set bits 4 through 9 to a value like this: INB[4..9]:=value
    You can even set them backwards like this: INB[9..4]:=value
    Thanks guys
    I am just finishing up the beginners book and I can add this great stuff to it.
    Just in time.
    H
