HELP!! RC Control of Boe Bot Pizzo Speaker
I have a Boe Bot that is set up to be controlled by a 2.4ghz Spektrum model aircraft 6 channel radio system (RC).I have 4 servos the 2 navigation servos and 2 servos for panning and tilting a camera. I want to add a pizzo speaker to be controlled off of an extra channel on my radio. I have tried several times to work this into my program but could not. I am not very good at programming. The program is attached to this message. Any help would be much appreciated!
Just in case you interested, there is a Propeller Board of Education available now. It can do all the things you're after without breaking a sweat.
Mike made a version of his FemtoBasic for the PropBOE. I'd think it would make the transition from BS2 to Prop a bit easier.
I've used my PropBOE to control a BOE-Bot with a Specktrum radio. I included a feature that lets you record the path of the robot to play back later (which I think is kind of cool, if I do say so myself).
Of course, there are plenty around here to help get the most out of the BS2 if you don't what to switch . . . yet. Did I mention the PropBOE has a lifetime warranty?
P.S. Don't tell erco I mentioned the Prop in the BS2 forum. (If he only knew how many times I've successfully resisted the urge to do so. . ..)
Many ways to get to Carnegie Hall, but the best is PRACTICE!
