Servo Headers Help on Prop BOE
I am trying to use the servo header to run my three wire GPS all it needs is a I/O pin and 5V and a ground. But when I try and use Pin 18 on the headers I do not get the signal through but when I use Pin 11 it works perfect. Is the header Sig pin just an out so it does not do I/O.
The servo header pins on the PropBOE are 5 volt tolerant, so the 3.9 k Ohm resistor might be attenuating the signal and preventing the propeller chip from sensing it.
I agree. I've had several 5V devices not able to see 3.3V logic with a series resistor (including servos).
