PSC firmware addition
I have a questions with regards to the Parallax Servo Controller firmware. I am communicating over a serial line and was wondering if the TX and RX lines are completely separate of each other? I believe they are but I ask this because I am trying to run the following PUB method, which sends the current counter value automatically, to my microcoontroller without me needing to query it.
I have launched this code into a new cog via:
However now when I try to send typical commands to the PSC such as Set Servo Position commands, I get no response from the motors. Nevertheless the RX line on the PSC is not being used so shouldn't the motors be running? Also does the baud rate of 38400 have any effect on this counter being transmitted effectively?
Thank you,
Robert
PUB TimeRequest | r, n
repeat
SendDataString(string("1.0"))
chksum := "1" + "." + "0"
value := cnt
'COMport1.dec(value)
repeat n from 0 to 3
'SendDataString(string(" "))
SendDataByte(value.byte[n])
'COMport1.hex(value.byte[n],2)
chksum += value.byte[n]
repeat r from 0 to 1
SendDataByte(chksum.byte[r])
'COMport1.str(string(" _ "))
'COMport1.hex(chksum.byte[r],2)
chksum := 0
VAR long TimeStack[20] PUB PSC_Propeller_firmware|Edata,Tdata Cognew(TimeRequest, @TimeStack)
Thank you,
Robert
It's not clear, to me, what you're asking or how you have the devices setup. A schematic would go a long way.
Much Appreciated!
I was thinking of adding a pause but was hoping not too because it interferes with the control of the motors.. Maybe someone has some other ideas? Eventhough the CNT ticks that get sent to the raspberry pi might not be exactly in sync with that of the propellers, they are still valuable because, offset as they may be, they are still coming in at a consistent rate. I plan on taking whatever count value comes in, running my entire code, taking a new count value, finding the change in the two values, dividing by clkfreq, and then finally using the change in time in my PID loop for the integral portion.
I'm still not following the CNT logic. CNT is a propeller register that increments on each clock tick. It's common to use CNT for deterministic timing and measuring stuff like frequency within the Prop.
As stated in post #5, CNT is sent at a constant rate to the RPi. If CNT is sent at a constant rate and CNT itself increments at a constant rate wouldn't the delta always be the same? I believe you are actually measuring serial port connection and processing parameters.
The PSC does not read the current position of the motors. The PSC reads it's internal register. The motor could be off but the PSC will return a value. You need encoders to complete the feedback loop.
I am using a USB connection so doesn't that mean that if i send 4 servo set position commands to the propeller continuously from the Raspberrry Pi, am I not supposed to be able to also receive continuous updates from the PUB TimeRequest methods I created above simultaneously? However when I do test it out, the servos do not move..
Although that is true, let me try to provide a counterargument to maybe correct my logic. You have brought up some interesting points. Delta would always be the very close to the same value, but not the same. I have done some experimental tests to prove that this CNT variable is valuable (without the position commands being sent). For example: I delayed the raspberry pi C code by 8ms and after solving for the actual loop time of the code using the change in CNT, I found that the code was executing at an average of approximately 8.125 m, sometimes even with larger time intervals like 16ms. This proved to me that the CNT timing is doing work and accurate enough to use in my actual code. Delta would always be close to the same, but if I don't get it from the CNT value, then I don't know what this change in time value is at all.
In my setup I have an IMU to complete the feedback loop.
I still don't get the CNT concept. Why not send one byte every millisecond or faction of a millisecond? Every time a byte arrives increment a variable. That would really cut down the overhead and free up the serial library.
The Propeller has set and forget counters which can act as a clock signal. If the RPi can detect a rising edge that would be even easier.
