Solder SIP to SMT?
Since PCB space is a premium, I've started looking at ways to reCap (lol) some of the realestate.
Manufacturers make many combinations of single and multi-capacitor arrays/networks.
Seems like a reasonable approach, except that most viable products are SIP variants.
I'd rather not have to account for holes in the PCB ATT; has anyone ever put down SMT/SMD-style pads and then soldered SIP arrays to them?
Kind of like the TSL237 frequency to light converter's flat 3 pins solder pads I guess?
I concur with the stress factor, I was thinking more along the lines of lying it down.
So that the pins are flat against the PCB.
This would keep the height to that of the thickness of the array.
The solder area wold be the entire side of the SIP pin
Thoughts?
Make certain the pads are long, though, as you want to bend the pins as close to the 'body' of the SIP as possible, and you want to solder the entire pin to the pad.
