Inline assembly: movsa / movda missing? — Parallax Forums
jac_goudsmitjac_goudsmit Posts: 418
edited 2013-02-14 08:12 in Propeller 1
Hi guys,
I know there is a "MOVA destination, #sourceaddress" pseudo-instruction which should be used to store cog addresses somewhere. The special instruction is needed to make the linker divide the source expression by 4 to obtain a cog address (32 bits per location).
But my code (a fairly long block of inline assembly in a .cogc module) contains some "MOVS destination, #sourceaddress" and "MOVD destination, #sourceaddress" instructions, and they result in the dreaded "relocation truncated" error. I'm thinking there should be MOVSA and MOVDA instructions that do the same as MOVA: divide the source address by 4.
Code fragment: (Note: I know this fragment can be coded differently but the function of the code is not the point here, just the problem that it's impossible to put a perfectly legal instruction in the inline assembly code)
__asm__ __volatile__ (
"    movs jmpins, #destination \n" // Error: relocation truncated
"    nop \n"
"jmpins \n"
"    jmp #0 \n" // destination patched with movs instruction
"destination \n"
// more code here
(PS my code is less than 200 instructions (based on line count of inline assembly) so the relocation truncated error is not because I'm overflowing a cog)
===Jac
  • altosackaltosack Posts: 132
    edited 2013-02-11 22:23
    The assembly directive ".cog_ram" directs the assembler to automatically adjust the addresses to longs instead of bytes within the cog memory space. I use this in *.S files (PASM sent to the C pre-processor before assembling), and I find this to be much more straightforward and easier to read than a bunch of in-line assembly (I assume it would work with in-line assembly, also, but I have never tried). Of course, then the entire driver must be written in assembly, but since I can use the pre-processor (with, for example, defines that work in both C and assembly), I find it to be very readable, configurable, and maintainable code.
    I have used movs, movi, and jump tables, and they all work fine with a .cog_ram directive at the top (I never use mova). I have an example of this type of code in this thread: http://forums.parallax.com/showthread.php/142441-Native-assembly-files-(*.S)-in-propgcc.
    David
  • jac_goudsmitjac_goudsmit Posts: 418
    edited 2013-02-12 07:32
    altosack wrote: »
    I added a ".cog_ram" directive to the top of my inline assembler and that made the errors go away. I'll verify the assembly output to see if the result is correct. Thanks!
    I've been considering switching to a .S module for this part of my project, and it's getting more and more tempting (not in the least because I was also running into the hard limit of 30 arguments per assembly fragment), but I want to stick to inline assembly as long as I can so that I can write an article about it on the PropGCC. I think there are probably many small projects out there that would benefit from combining small fragments of very fast assembly that runs on the same cog as other code in C/C++. When using Spin, it's not possible to make this combination, and when using a .S module, the code gets physically separated in multiple files which makes the feature less obvious.
    I didn't really want to use those MOVA/MOVSA/MOVDA instructions either (it's too easy to make mistakes). I wonder if .cog_ram should be the default and the MOVA instruction should be deprecated.
    Either way, I still think if there is a MOVA there should probably also be a MOVSA and a MOVDA.
    Thanks again!
    ===Jac
  • ersmithersmith Posts: 6,251
    There's no movsa or movda because originally I intended to make movs and movd take addresses by default; but then I found that some programs rely on using them with constants rather than addresses. Unfortunately there is really no good solution. In LMM, XMM, and CMM modes addresses have to be byte addresses, but in COG mode long addresses are more natural. The .cog_ram directive is probably the least bad solution. I do recommend moving your code out into a separate .S file if it's at all significant. Inline assembly is really only suitable for short snippets of code, as you're discovering!
    Eric
