Propeller Tool Communication error
I was in the middle of a bunch of edits when I used F10 to download the latest changes to the Prop.
The Propeller Communication dialog window opened with the little dots at the bottom and it stopped at the second dot from the left.
Nothing would make it continue.
I rebooted the prop, removed and reinserted the USB plug into the PC without help.
I then attempted to close the Prop Tool and received a dialog box which had a check box to report the error to Parallax but then after including the details above, I attempted to send this to Parallax and received a 404 error.
My internet is working fine otherwise I could not get this message to the forum.
I have copied and pasted the details below.
EurekaLog 6.0.18
Application:
1.1 Start Date : Sun, 10 Feb 2013 09:05:04 -0500
1.2 Name/Description: Propeller.exe - (Propeller Tool)
1.3 Version Number : 1.3.0.0
1.4 Parameters :
1.5 Compilation Date: Thu, 16 Jun 2011 16:03:03 -0500
1.6 Up Time : 1 hour, 1 minute, 30 seconds
Exception:
2.1 Date : Sun, 10 Feb 2013 10:06:35 -0500
2.2 Address : 00599936
2.3 Module Name : Propeller.exe - (Propeller Tool)
2.4 Module Version: 1.3.0.0
2.5 Type : EAccessViolation
2.6 Message : Access violation at address 00599936 in module 'Propeller.exe'. Read of address FFFFFFFF.
2.7 ID : A68E
2.8 Count : 1
2.9 Status : New
2.10 Note :
Active Controls:
4.1 Form Class : TMainForm
4.2 Form Text : Propeller Tool - Multi_Midi_Output
4.3 Control Class: TPTreeView
4.4 Control Text :
Computer:
5.2 Total Memory : 3561 Mb
5.3 Free Memory : 2129 Mb
5.4 Total Disk : 441.51 Gb
5.5 Free Disk : 374.72 Gb
5.6 System Up Time: 1 hour, 2 minutes, 49 seconds
5.7 Processor : AMD A6-3420M APU with Radeon(tm) HD Graphics
5.8 Display Mode : 1600 x 900, 32 bit
5.9 Display DPI : 96
5.10 Video Card : AMD Radeon(TM) HD 6520G (driver 8.900.7.1000 - RAM 512 MB)
5.11 Printer : HP Officejet Pro 8600 (driver 6.1.7601.17514)
Operating System:
6.1 Type : Microsoft Windows Vista (64 bit) EDIT: NOTE Prop tool reporting this incorrectly. This is a Win 7 OS
6.2 Build # : 7601
6.3 Update : Service Pack 1
6.4 Language: English
6.5 Charset : 0
EurekaLog 6.0.18
Application:
1.4 Parameters :
Exception:
2.7 ID : A68E
2.8 Count : 1
2.9 Status : New
2.10 Note :
Active Controls:
4.4 Control Text :
Computer:
Operating System:
6.2 Build # : 7601
6.5 Charset : 0
