A little camera help needed
NWCCTV
Can someone explain if/how I would go about interfacing this camera with a prop Boe or QS?
https://www.sparkfun.com/products/11610
Don't expect to be able to do things with the actual image. What you get from the camera is a JPG file and the Propeller doesn't have the memory or processing power to decode the image from the JPG file. You could store the JPG file on an SD card as a file and later decode it using a PC.
Have a look at the documentation from SparkFun's webstore page.
