Keypad inputs
I am working on a system where when you enter a password with the keypad it will say open on the LCD and control a led light and sound. I tried using an if statement and adding the Keypad.BIT15+Keypad.BIT14 code with each other but did not work. Can anyone steer me in the right direction for the proper coding? Thank you.
I am using BS2 education board.
' Alarm System
' {$STAMP BS2}
' {$PBASIC 2.5}
[ Constants ]
NotArmed CON 1
Armed CON 2
Triggered CON 3
Frequency CON 250
[ Pins ]
LCD PIN 15
Servo PIN 14
Sensor PIN 13
Alarm PIN 12
Green PIN 11
Red PIN 10
[ Variables ]
seconds VAR Word
counter VAR Word
state VAR Nib
row VAR Nib
column VAR Nib
keypad VAR Word
temp VAR Nib
duration VAR Word
freq VAR Word
[ Intialization ]
PAUSE 1000
SEROUT LCD, 84, [22, 17]
state = NotArmed
[ Main Routine ]
DO
SELECT state
CASE NotArmed
GOSUB Prompt_to_Arm
CASE Armed
GOSUB Alarm_Armed
CASE Triggered
GOSUB Attack_Mode
GOSUB Alarm_Triggered
ENDSELECT
LOOP
'================[ Subroutines ]===============================================
[ Prompt to Arm ]
Prompt_to_Arm:
SEROUT LCD, 84, [12, 130, "System is not" ,13, 154, "Armed"]
HIGH Green
LOW Red
GOSUB Arm_System
RETURN
[ Arm System ]
Arm_System:
GOSUB ReadKeypad
IF Keypad.BIT15 THEN
SEROUT LCD, 84, [12, "System is Arming"]
FOR seconds = 5 TO 0
SEROUT LCD, 84, [149,208,231, DEC seconds, " Seconds left"]
HIGH Green
LOW Red
PAUSE 200
HIGH Red
LOW Green
PAUSE 200
PAUSE 600
NEXT
state = Armed
SEROUT LCD, 84, [12,208, 220,221,220,220,222,228, "System is Armed"]
ENDIF
PAUSE 2000
RETURN
[ Prompt to Disarm ]
Prompt_to_Disarm:
SEROUT LCD, 84, [12, "Type password to", 13, 153, "disarm"]
GOSUB ReadKeypad
IF Keypad.BIT0 THEN
SEROUT LCD, 84, [208, 220,221,220,220,222,228]
state =NotArmed
ENDIF
PAUSE 1000
RETURN
[ Alarm Armed ]
Alarm_Armed:
DO
GOSUB Prompt_To_disarm
GOSUB Check_Sensors
HIGH Red
LOW Green
LOOP UNTIL state <> Armed
RETURN
[ Attack Mode ]
Attack_Mode:
SEROUT LCD, 84, [12, 131, "You will be", 13, 150, "Exterminated"]
PAUSE 1000
FOR counter = 1 TO 5
PULSOUT Servo, 850
PAUSE 20
NEXT
PAUSE 500
PULSOUT Servo, 650
PAUSE 20
NEXT
RETURN
[ Check Sensors ]
Check_Sensors:
IF IN13 = 1 THEN state = Triggered
RETURN
[ Alarm Triggered ]
Alarm_Triggered:
DO
SEROUT LCD, 84, [12, 133, "Alarm", 13, 151, "Triggered!"]
FOR counter = 1 TO 15 ' Sound 15 alarm tones
FREQOUT Alarm, 100, Frequency
PAUSE 100
NEXT
IF IN13 = 0 THEN
state = armed
ENDIF
LOOP UNTIL IN13 = 0
[ Read Keypad ]
ReadKeypad:
keypad = 0
OUTL = %00000000
DIRL = %00000000
FOR row = 0 TO 3
DIRB = %1111
OUTB = %0000
OUTA = 1 << Row
DIRA = 1 << Row
temp = 0
FOR column = 0 TO 3
INPUT (column +4)
temp = temp | (INB & (1 << column))
NEXT
keypad = keypad << 4 | (Temp REV 4)
NEXT
RETURN
