Laser cutters
Two questions, is there anyone in the Phoenix area that has one and is it possible to cut clear PVC with one if it has paper backing.
Jim
Jim
Jim
What PVC are you using that's clear and has a paper film on it? That sounds more like acrylic. Either cast or extruded acrylic is infinitely cuttable on a laser, and leaves a good edge with no scorch marks.
-- Gordon
2. With pliers or Vise Grips, heat the copper in the flame of a propane torch.
3. Touch the heated copper to the suspect material to melt it and pick up a glob.
4. Return the copper and melted plastic to the flame.
5. If the molten plastic on the copper burns with a green flame, it contains chlorine and should not be laser cut.
(the oxides are not volatile), chlorine compounds make copper chloride which sublimes at lower temperature I think,
and colours the flame much more strongly. To avoid being fooled check the flame colour with and without the plastic sample - its
very different. There could also be yellow in the flame due to tiny amounts of sodium impurities, there usually is,
ignore this.
And don't breathe in the vapours!
Best to test on something that you know will get a positive result such as a piece of PVC pipe and also test on something that you know will get a negative result such as acrylic or ABS. You don't need much material to be picked up on the hot copper, just a half-second light touch is enough.
To be specific, the chlorine gas is poisonous to us, but the corrosive element is hydrogen chloride, which when mixed with the moisture in the air produces hydrochloric acid. That is the stuff that eats your precious little laser cutter parts.
Brian I will contact via PM.
Jim
