Question about PropBOE and Hanno's 12 Blocks
Is the PropBOE compatible with Hanno's 12 Blocks? I would like to use 12 Blocks with the PropBOE but cannot seem to get it to communicate. My propellor QuickStart Demo board works fine with 12 Blocks, but I cannot seem to find any communication setting in 12 Blocks that works with the PropBOE.What am I missing?
Steve
Steve
Hanno
Steve
I was able to:
- connect the PropBOE to my PC running 12Blocks
- select the DemoBoard library and the "Auto" port
- set up the program as follows
- press "Run" to blink the LED
Hanno
Same USB port? Same USB cable?
Does it happen to be a USB3 port? At one time, I believe there were problems with the Propeller BOE on USB3 ports. If so, try a USB2 port instead.
Have you tried the Propeller Spin Tool with the Prop BOE to see if it works?
I switch back and forth between board types and programming tools all the time without any problems. The only thing I avoid are the USB 3 ports on my one laptop.
I now have the PropBOE and 12 Blocks running. I was initially using Connect/Disconnect just to try to verify that 12 Blocks could see the PropBOE without writing a program. That always failed and gave an error. Using RUN and the sample code above, it connected and ran the sample code on the first try.
Thanks for your help,
Steve
I like playing with 12Blocks. Hanno did a super job on it...and ViewPort...and I recently purchased a PropScope, which is cool, too!
Thanks for your enthusiastic support!
Hanno
