Spinneret Resurection
doggiedoc
I while back I fried the Wiznet chip on one of my Spinnerets. Today I transplanted the W5100 from an Aduino Ethernet Shield I didn't figure I'd ever use, to the ailing Spinneret. I was able to successfully remove the bad chip from the spinneret and the good chip from the shield using a hot air tool. It took a couple of tries to get it soldered on strait and a few more tries to remove a few solder bridges. Dang that pitch is tight!
Whew!
Doc
Whew!
Doc
Well played, good sir!!!
I suppose that practising on junk boards is ideal.
The big advantages of surface mount might just be that it is easier to insert resistors and capacitors in forgotten places as they don't need holes and in many cases, one might just build a tiny one-sided board.
Actually, there's a "Kit" that costs about $30.00 for the full version of it that teaches you SMD soldering and you can desolder and try again. I will dig up the link and post it later. I bought one for my own use, just have not gotten around to messing with it yet.
Edit: Here's the link: http://www.appliedinspirations.com/appliedcontent/Projects/SMD-Soldering/SMD_SolderingKIT.html
Could you give us some info on the hot air tool that you used?
C.W.
EDIT: it looks a lot like this
http://www.amazon.com/Uchida-Embossing-Heat-Tool-Stand/dp/B000QTFH58
C.W.
