How to Convert XYZ output from Accelerometer to Degree only ?
I used MMA7455 3-Axis Accelerometer Module, and i want to convert XYZ output from accelerometer to be degree only.
Help me to create the code in BS2SX, to convert this output. Or what anyone have the code ?
Please share it
Please share it
I'm sure there are many places online that give a better explanation than mine. The angle calculation will depend on the precision and range of the accelerometer. You will likely need to use the arcsine function to calculate the angle of tilt from the raw accelerometer value.
