Nothing to do with Parallax
Well, they do have to deal with the IRS. In an e-mail from the IRS
The IRS has rejected your federal return. This means that your return has not been filed.
Here's the reason for the rejection:
Field/Xpath: /efile:Return[1]/efile:ReturnData[1]/efile:IRS1099R[1]/efile:RecipientsName[1]
Issue : The XML data has failed schema validation.
Well, that's clear. I know just what to do. By the way, the FAQ link in the e-mail 404's
John Abshier
John Abshier
John Abshier
The rejection notice seems to say something wrong with your 1099R.
This sounds like a scam for some hostile software, but it just could be a computer glitch.
I was enrolled as an Enrolled Agent of the IRS, Department of Treasury to 10 years. And I have NEVER heard of the IRS rejecting a Federal return. In fact, it may be statutorily impossible for them to do so.
They may request clarification, they may audit a return, and you may have to amend a return. But once the return is filed, the statue of limitations on your return are activated. With no filing, there is no statue of limitation of your obligations. I don't think the Fed can revoke your attempt to file.
There are significant penalties for filing an obvious capricious return.
BTW, I never file electronically. Everything is done on paper and via registered mail. The electronic filing process is not going to protect you as well as having sent a hard copy and having proof of sending such.
If you have trouble with your return, your local IRS office will help you fill out the forms for free. And if you don't like what they did, you have three years to amend.
It is a scam if it is unsolicited email
It is a computer glitch if one has been trying to do an on-line electronic filing and got into error messages.
All the data for you tax filing -- W-2s, 1099s, K-1s and so on are sent to the IRS in duplicate by the originator and then this data is matched to your filing. If that data has not arrived or is in some way flawed, there is nothing to match.
I suppose in an electronic filing, that might cause this kind of a rejection. If you filed by paper, somebody would just have to sit on the return until they either sent you a letter or got good data to match or they decided to accept what you offered.
John Abshier
John Abshier
A typical computer glitch. One programmer doesn't know what another programmer is told to do.
I will continue to file all forms in paper, send by registered mail, and let a human trap the errors. It sounds like you spent more time on a paperless form that you would have spent on a conventional filing by mail.
