propeller c3 spi problem
Hi everyone
I have some problem about c3 spi
now i want to use c3 spi A/D to get the data and write into SD card
if I separately use them it ok
but when i use together the A/D value always 0
how can i use A/D and SD card together?
thanks
thanks
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
con
RX1 = 31 ' programming / terminal
TX1 = 30
SDA = 29 ' eeprom / i2c
SCL = 28
SD_CS = 25
SD_DI = 9
SD_CLK = 11
SD_DO = 10
OBJ
pp : "po"
sdcard : "dave_fsrw"
term : "FullDuplexSerial"
num : "numbers"
var
long g_temp1
PUB demo | check ,value
term.start(31, 30, 0, 115200)
pp.SPI_Init
check := \sdcard.mount_explicit(SD_DO, SD_CLK, SD_DI, SD_CS)
check := \sdcard.popen(string("NMEA.txt"), "w")
'value:=10
repeat 10
AD_Test
term.dec(g_temp1)
'wind direction
term.tx(13)
sdwrite
WaitCnt(ClkFreq+ Cnt)
sdcard.pclose
\sdcard.unmount
PUB AD_Test
pp.AD_Init
g_temp1 := pp.AD_Read( 0 )
PUB sdwrite
sdcard.pputs(num.ToStr(g_temp1,10))
so i can't get the A/D value then write into SD card?
I have try to use fsrwFemto and sdspiFemto but it dosen't work
I don't know how to solve my problem
are there someone had used propeller c3 both A/D and SD card?
from time to time the SD-Card-driver is started to write the data and then stopped again? Would that work?
Surely the C3 has everything "on board" but how about connecting an external SD-Card-socket to some pins to keep the SD-card
away from the SPI-bus?
best regards
Stefan
Hi StefanL38
I try to completely stopped and started the driver but in the sd card only show one value
because if i re-start the SD-Card-driver the value before will clear
Make sure you close the file before stopping the SD card driver.
