Quickplayer Launcher spin and retrotext spin
skylight
Hi, I finally got hold of a TRRS to RCA cable to plug the Quickstart/Human Interface combo to my TV, I have programmed the Prop with The Launcher.spin program which also includes the retrotextTV.spin driver from the PropellerPowered website which looks like it outputs both NTSC and PAL, I need PAL for my TV.
The display is chopping though I can see some fonts for the launch screen (Hard to read what it says) so i'm presuming that my TV is receiving an NTSC signal as opposed to the PAL signal
Looking at retrotext.spin and retrotext_TV.spin I can see the lines of code at the beginning regarding NTSC do I need to comment these out?
attached is retrotextTV.spin and retrotext.spin and the Launcher.spin programs
Edit: Found the problem is with the TRRS connection on the human Interface Board not the code, Launcher .spin now shows screen with "SD Card not Found" I think I can get around that with the new version of frsw.spin? which supports SDHC cards
see here:
http://forums.parallax.com/showthread.php/145637-Human-Interface-Board-TV-out-issue?p=1160590&viewfull=1#post1160590
see here:
