Is this NVram a reasonable replacement for SD?
So I was digging through my chips and found one of these chips, I forgot I had it. Its a maxim 1megabyte 70ns NVRam dip chip.
http://www.digikey.com/product-detail/en/DS1265AB-100%2B/DS1265AB-100%2B-ND/1768795
I was thinking I could use it as a fast storage medium, or even as ram for a multi-prop setup to share data. I have a ton of the 20mhz quad spi microchip srams around also, that could easily be turned to nvram by adding battery back up, the there is also quad spi flash! This maxim ram is parallel so it will take some kind of logic chips to even get it to a reasonable pin count,
Now obviously this chip is going to be a major PITA to get connected with a propeller, but s it worth it, I mean would it give better performance than other solutions. This chip is pretty pricey so it would be nice to find a use for it someday.
Emulating older 8 bit CPU's or capturing small blocks of high speed data for the prop to analyze are about the only apps I can come up with.
