Can't pass global variable after cognew command
My challenge is to control two steppers with IR distance detection. I designed it so that the top object initializes three cogs, one for each of the two steppers and an IR control. The idea is that the main method in the IR control (which includes two extra methods for global variables 'A' and 'B') copies the value from from the IR detector and passes it to the two global variables, 'A' and 'B'.
The left stepper then calls method 'A' and the right stepper calls method 'B' to get the corresponding value/s. The problem is that once I issue a cognew command to the IR control object I can no longer get those global values. I'm debugging with the PST using 'copy' and 'paste'. I'm stumped.
{ works with cognew command to pst } CON _xinfreq = 5_000_000 _clkmode = xtal1 + pll16x OBJ ir : "IrDetectorV6" pst : "Parallax Serial Terminal" VAR byte cogT long indexA, indexB, A_Side, B_Side, stack[20] {PUB Start : success Stop success := cogT := cognew(Main_Sensor, @stack) + 1 PUB Stop If cogT cogstop(cogT~ - 1) } PUB Main_Sensor | dist ' : result pst.StartRxTx(31, 30, 0, 115_200) ir.init(26, 27, 25) repeat dist := ir.distance A_Side := B_Side := dist ' waitcnt(clkfreq/100 + cnt) pst.Str(string(pst#PX, 11)) pst.Dec(dist) ' waitcnt(clkfreq/3 + cnt) ' Foward_a PUB Foward_a : result 'left wheel result := A_Side pst.Str(string(pst#PX, 11)) ' dist := ir.Distance pst.Dec(result) ' pst.Str(string("/100", pst#CE)) waitcnt(clkfreq/3 + cnt) PUB Foward_b : result 'right wheel result := B_Side
