Forward stability: Integrating optical encoders and RC input — Parallax Forums
FalconFalcon Posts: 191
edited 2013-12-26 06:16 in Robotics
I'm welding together the chassis for an all-terrain rover at the moment but am looking ahead at the electronic needs.
The rover will use two 24VDC powerchair motors in a differential steering configuration controlled by a Sabertooth 2x25 using steering input from either a Futaba or homemade XBEE radio I plan to use a Prop 1 processor on the rover. I have a stand-alone video camera and TX (separate from the Propeller system) to allow operation from a remote, indoor location. Tests with the motors on a plywood mock-up showed that trim adjustments were needed pretty often to keep it going in a straight line. This was partially due to the nature of "all-terrain", and the gravel roads it was tested on. For that reason I've been researching optical encoder feedback to help maintain equal wheel speeds. Encoders can be easily mounted where brake assemblies were removed.
I've seen the quadrature encoder objects in the OBEX, and have read through "Running DC Motors with attached Incremental Encoders" in Chapter 28 of Harprit Sandhu's excellent book "Programming the Propeller with SPIN". All of these examples control a single motor/encoder, and I don't remember any that integrated RC control.
Question: Is there a Propeller example anywhere of two motor/encoders used in a differential steering configuration? Or how to modify any of the existing OBEX Objects to read two encoders.
I also plan to use RC control. It looks like most lot of the robot examples with encoders I've seen are configured for autonomous navigation without external input.
Question: Is it possible to integrate RC control with the feedback provided by quadrature encoders without the two steering inputs fighting each other
My idea was to limit the use of the encoder feedback to when the RC steering input was at a null position +/- 1 or 2 degrees. Outside of that narrow envelop the encoder feedback would be ignored.
I appreciate any comments, suggestions, remarks or links.
Falcon
  • shimniokshimniok Posts: 177
    edited 2013-01-27 20:10
    Is the idea to use encoder feedback in the 'dead band' to steer straight or something? I don't see why that couldn't be done.
    There's probably be an output signal as well as the RC RX input. You'd probably want to try to sync the Prop-generated signal with the RX so that when switching back and forth there aren't any glitches. Rather than switching between Prop generated signal and RX signal, you could have the Prop generate the signal continuously. In the deadband, pulse width is set based on encoder feedback. Outside of that, you set the PW to match that of the incoming RX signal. Let me know if I'm not explaining well :)
    edited 2013-01-28 07:02
    In my Mecanum wheeled robot project, I use the encoders to make sure the wheel speeds match the expected values generated by the RC input and wheel speed equations.
    You might find something useful in the code. The most up to date version (on the forum) is in post #69.
  • FalconFalcon Posts: 191
    edited 2013-01-30 16:00
    shimniok wrote: »
    shimniok,
    I think your explanation was fine. I think getting the RC signal into the Prop will not be too difficult. I think the problem will be integrating the "mixed" encoder signals with the RC.
    falcon
    edited 2013-01-30 16:02
    Duane Degn wrote: »
    Duane,
    I'll have to try to work my way through that. My SPIN skills are still at a kindergarten level. It does prove the concept i have in mind.
    falcon
  • HarpritHarprit Posts: 539
    edited 2013-12-21 14:34
    You may want to look thorough my book on running motors with PIC micro controllers.
    It has a section on running an encoded servo remotely with an R/C signal/controller
    Like what the guys on myth busters do all the time.
    It is quite possible and easy to run two motors with two timers on a Prop
    /code
    PRI Run_Motor(Piny,Pinx)|WaveLength,period,WaveLengthx,periodx 'subroutine to PWM the output line
    dira[diry..pwmy]~~
    dira[dirX..pwmX]~~
    ctra[30..26]:=100 'Set this cog's "A Counter" to PWM
    ctrb[30..26]:=100 'Set this cog's "B Counter" to PWM
    ctra[5..0]:=Piny 'Set the "A pin" of this cog to Pin=PWM
    ctrb[5..0]:=PinX 'Set the "B pin" of this cog to Pin=PWMX
    frqa:=1 'Set this counter's frqa value to 1
    frqb:=1 'Set this counter's frqa value to 1
    PulsWidth[1]:=0 'Start with position=0
    PulsWidth[2]:=0 'Start with position=0
    WaveLength:=clkfreq/10_000 'Set the time for the wave L to 1000 cycles
    WaveLengthX:=clkfreq/10_000 'Set the time for the wave L to 1000 cycles
    period:=cnt 'Store the current value of the counter
    periodX:=cnt 'Store the current value of the counter
    repeat 'power PWM routine.
    phsa:=-PulsWidth[1] 'Send a high pulse for Pulsewidth counts
    period:=period+WaveLength 'Calculate wave length
    phsb:=-PulsWidth[2] 'Send a high pulse for Pulsewidth counts
    periodX:=periodX+WaveLengthX 'Calculate wave length
    if periodX>period
    waitcnt(periodX) 'Wait for end of wavelength
    else
    waitcnt(period)
    /Code
    Harprit.
    You can call me at 217 369 8737 to discuss.
  • ercoerco Posts: 20,256
    edited 2013-12-21 19:54
    Edit: This thread is nearly a year old, and the OP is long gone. I wish I would have realized that before I typed all the stuff below... :)
    Sounds like a great project. And a very complicated one. I love encoders indoors, but on an outdoor all terrain robot, my guess is that you'll need a lot more than that to get anything close to a straight line (and please don't tell me you have a caster). For tackling bumpy gravel roads, you probably need 4WD skid steering, pneumatic tires, a compass and GPS. Encoders can swag distance travelled & amount of turn
    BTW, pneumatic tires introduce another variable: tyre pressure. Encoders can make sure your wheels all turn the same amount, but if one side has significantly lower tire pressure, it will turn toward that side.
    Erco, I'm not gone, just working on some other parts of the rover.
    Harprit, I appreciate you taking the time to respond. I actually have several of your books including that one. I highly recommend them.
    I've since bought the Kangaroo X2 from www.dimensionengineering.com and two OMRON E6B2-CWZ6C rotary encoders. I haven't had the time to get it all together but hope to in the new year.
    Falcon
