Troubles convert a long into string for C3 + SD-Card (write string to file (sdcard)
nomad
hi,
i am working with the C3-board and the SD-Card
please have a look to my oldThread " Troubles with PropC3 and SD-Card"
i am working with c3-quadV2-SD-01.spin (its adapted from ggg558877)
and with dave_fsrw.spin (from Dave Hein)
in the moment the code works with static strings
a) in the DAT Section or
b) str := "4"
all stuff ok
but i would work with my DummyDatas (aka GPS-Datas) as
Long latfloat := 47.51332
in the "dave_fsrw.spin" - drive
i can do with
sdcard.pputs(@str) or
sdcard.pwrite(@str,8)
but i have big troubles to convert the latfloat to a stringBuffer which is correct
for pputs or pwrite ?
in the c3-quadV2-SD-01.spin you find some experiments
result : not printable chars ?
have somebody a way to solve this problem ?
- c3-quadV2-SD-01.spin
- dave_fsrw.spin
thanks for help and hints
regards nomad
b) str := "4"
all stuff ok
i can do with
- dave_fsrw.spin
regards nomad
spin
23K
' this is wrong: gpsstring := FS.FloatToString(latfloat) ' term.str(@gpsstring)Here gpsstring already holds the address of the converted string. In order to print it a simple term.str(gpsstring) is sufficient. Note that pputs and pwrite also just take an address value (e.g. result of FloatToString) so @ isn't required.CON _clkmode = XTAL1|PLL16X _xinfreq = 5_000_000 OBJ serial: "FullDuplexSerial" fstr: "FloatString" VAR long latfloat PUB null serial.start(31, 30, %0000, 115200) waitcnt(clkfreq*3 + cnt) serial.tx(0) latfloat := 47.51332 serial.str(fstr.FloatToString(latfloat)) serial.tx(13) DATthank you for your help :-)
today i make with your snippets some experiments
and make then a reply
regards
nomad
many thanks for your code.
its running with
- 1 write dummyDatas (lat,lon,alti) into gps1.txt of the SD-Card
- 2 read dummyDatas in 1 line to PST
--- code
- WRITE
sdcard.pputs(fstr.FloatToString(latfloat))
sdcard.pputs(" ")
sdcard.pputs(fstr.FloatToString(lonfloat))
sdcard.pputs(" ")
sdcard.pputs(fstr.FloatToString(GPSaltitude))
- READ to PST
bytefill(@sbuf, 0, BUF_SIZE) ' clear buffer
readln(@sbuf, 80) ' read line from file
term.str(@sbuf)
as attachment a screenshot as
thanks for your help :-))
regards
nomad
