Stingray changes (now with orange wheels) — Parallax Forums
RobotWorkshopRobotWorkshop Posts: 2,307
edited 2013-01-28 05:45 in Robotics
I just noticed that the pictures of the Stingray kit now show that the robot has the Orange wheels. Is that what comes with the kit now? Are there any other changes?
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-01-25 13:04
    Yea, The price!!!!
    edited 2013-01-25 13:12
    Yes. The price makes it a very good value. I have a Stingray and it is a great platform for a mid size robot. Some people didn't like the high speed and there was talk about changing the gearing of the motors. I was just wondering if the only change was the wheels or if the motors have also been altered. I'd just like to know if the motors included with the kit still have the exposed shaft on the back so that encoders can be fitted. It isn't specifically called out on the product page. I think that should be mentioned in the motor description since it is a good feature and a plus for the kit.
    edited 2013-01-25 20:34
    Yep, there still is an exposed shaft for encoder attachment. The new encoders will soon be available with a mounting kit specifically for Stingray. It's a two-fin disc on the motor shaft.
    -MattG
    edited 2013-01-26 09:57
    -MattG
    You may want to add a note on the Stingray product page mentioning that the motors have an exposed shaft. That is a big plus that a lot of motors don't have. It would be good to call attention to that.
    Robert
    edited 2013-01-26 12:22
    Still the 7.2v 300RPM motor's though... :/
    edited 2013-01-26 14:36
    Roy Eltham wrote: »
    Roy: That's only 5 rev/sec, so what maybe 7-8 feet per second? :)
    That's perfect for fine speed control in the LFO (line following open) at Expo. Maybe a little slow even... :P
    edited 2013-01-26 14:43
    Ive seen a few videos of the stingray, and I have to say I really like the speed of the motors they can always be pulsed slower, depending on the torque. I also agree the back shaft is super important, since the motors dont come with encoders. That back shaft makes adding some home made ones real easy, what is a two fin design, two encoder wheels, or like two teeth on the disc?
    Im planning on purchasing this kit in two weeks, I was wondering if one of the parallax employees could tell me if it will still be on sale? Also I emailed sales but never heard back, I really like the blue wheels much better, is there anyway to still get those with the kit? I noticed the motor only kit still comes with blue wheels.
    edited 2013-01-26 15:53
    My stingray with the stock motors (with third party encoders) and using the MSR1 (so not the best motor driver), can't do a square to save it's life, even going slow... the stock motors just can't go slow enough reliably. Using third party motors with much high gear ratios (lower RPMs) results in much better results. I guess I should test the stock motors with a different motor driver to see if that helps them perform better at lower speeds.
    Also, erco, I am shocked to hear you defending them, you were one of the folks blasting them in the past.
    edited 2013-01-26 16:29
    The color of the wheels indicates the rubber hardness http://banebots.com/c/WHB-WS-498
    orange are medium and blue are harder...
    edited 2013-01-26 18:18
    Ray, im not sure what the msr1 is, I did a google search and it looks to me like its a parallax robot control board?
    http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/28230-PropellerRobotControlBrd-v1.0.pdf
    This is using the H-Bridge chip that I planned on using, I also use this chip to control my roomba, its an it is speced at STM l6205 2.8 continous to 5.something amps peak. If this is what you are using what exactly is wrong with the driver, it seems like it has more than enough power for the sting ray... Now youve got me a bit worried about driving this thing at lower speeds :/
    edited 2013-01-26 21:01
    rwgast_logicdesign:
    Yes, the MSR1 was a board parallax originally sold with the Stingray, it's been discontinued for a while though.
    The datasheet for that part says the operating supply voltage should be between 8 and 52 volts. However, those motors are 7.2v and I ran them at 7.2v (standard RC battery). Maybe that is why it didn't work so well for me?
    The other motors I used that worked better were 12v, and I ran them from both a 12v SLA battery and a 3S Lipo (11.1v). Of course, they were also geared with a much higher ratio, so the output speed was much lower.
    edited 2013-01-26 21:20
    Roy Eltham wrote: »
    Sorry, I guess my subtle sarcasm didn't come thru my post. Yes, they are hopelessly undergeared and way too fast, as evidenced by the plethora of posts here about baseboard damage!
    edited 2013-01-26 21:36
    Yeah, ok, I wasn't sure, sarcasm is a bit hard to read in text sometimes.
    rwgast_logicdesign, Check out these: http://www.pololu.com/catalog/category/116 I'd get the 12v, 100:1 or 131:1 ratio ones... I have those with the encoders. Got them during one of the black friday sales. They most fit right in, I think I might not have been able to get all 3 screws in without drilling, but I don't recall (it was over a year ago, and I can't easily check right now).
    edited 2013-01-26 21:50
  • zappmanzappman Posts: 418
    edited 2013-01-26 22:10
    Roy Eltham wrote: »
    I have the Pololu motors in my Stingray, all 3 motor mounting holes match up with the Stingray. The shafts that drive the wheels are shorter on the the Pololu motors but are just barely long enough to reach the 2nd set screw on the Stingray wheel hubs. I bought my Pololu motors motors during their Blackfriday 2012 sale. My Stingray came with the orange wheels.
    edited 2013-01-26 23:04
    @Roy, ya ive done alot of work using that chip and 7.2v is barely enough to run it. It goes in to low voltage lockout at 7v. It drops around a volt so your motors would only be getting around 6v. If you supplied it with 7 cells (NiMH,NiCad) you would be giving the motors a perfect 7.2v and the chip its required 8. The l6205s charge pump is finiky under 10v also. Im not sure why parallax would supply this chip with the original stingray kits. Its a good chip but it doesnt work well in lower voltage situations. I plan to use a 19.2v NiMH pack and either chop the motors power by keeping the duty cycle @ 37%, giving the motors 7.2v max, or setting up a switching regulator to power the chip (finding an adjustable 10amp switching regulator isnt easy).
    I like the top speed i see in the videos on youtube, but ill have to really test things things at low duty cycles, if I have the same issues as roy ill definately be trading them in for a pair of the polulu motors linked too. Speed is fun but if having it means theres not enough torque when going slow then its not worth it.
    Has anyone thought about just regearing the things? The data sheet on parallax for stingray shows the gearbox its only 3 spurs, im not sure how easy popping the gearheads is though... the problem with most of these replacement motors is they lack a back shaft from what I can tell, and have no place to put encoders. Erco where did you get $10 replacements?
    edited 2013-01-26 23:29
    erco's $10 ones are ebay specials from China. At least the Pololu one's have encoders included. I'm sure you could find something similar for less if you shopped around, but I like Pololu.
    edited 2013-01-27 00:12
    Im not sure how busy you are at valve these days, btw congrats on that, definately a cool place with cool people. Maybe you could throw a 12v battery on the stingray and let us know what kind of results you get. If you are afraid of damaging the motors just keep the duty cycle under 60%. Do you know how these motors handel overvoltage?
  • ajwardajward Posts: 1,130
    edited 2013-01-27 09:38
    It's just the beast marking it's territory! ;-)
    edited 2013-01-27 12:16
    ajward wrote: »
    Are you talking about me, or the Stingray? :)
    edited 2013-01-27 12:18
    Real men make their own wheel encoders! :)
    edited 2013-01-27 18:13
    Here's a pair for you...
    -Tommy
    1024 x 768 - 129K
    edited 2013-01-27 18:34
    Ttailspin wrote: »
    -Tommy
    About how much weight can you put on this and still have it move smoothly?
    edited 2013-01-27 18:49
    I ran the motors spec through an online caclulator last night. If you keep it on flat ground, you can load it at about 10-15lbs and get decent acceleration. If you want to get up 20 degree hills with fast acceleration I wouldnt go over 5-10lbs. And if you dont care much about acceleration and can live with 1ft/s squared than 20+ on flat ground,
  • Ray0665Ray0665 Posts: 231
    I have one of the original Stingray kits with the msr1 control board and 7.2V motors and six inch diameter wheels. Ive added the QME01 wheel encoders three pings and a 4x20 lcd display, the line follower kit from parallax and the line scan camera also from parallax. I do recommend front bumpers of some kind to protect the pings in crashes. I used 3 inch wire drawer pulls on mine.
    Regarding the speed and torque issues. The motors are geared 30:1. if you drive the motors open loop you will find it very fast, and with enough torque to pull itself along quite nicely. Slow speeds are a little problematic requiring a minimum open loop setting before the thing will even move.
    My interests, however, are in autonomous motion and have built navigate to waypoint and pid control into my bots software. I have found the issues with low speed control a non issue with pid control since pid will increase torque to achieve the set speed.
    Wheel slippage and inaccuracies inherent in the motors and wheels especially when reversing direction and turning overwhelm any other issues. Never the less I am able to drive the bot fairly accurately indoors. for example I have a test program that drives the bot 5 meters forward then drive a 1 meter square making all right turns then another 1 meter square making all left turns and then drive back to the starting poing landing within 10-20 cm of the starting point most of the time (failures are very spectacular). I generally keep the speed at about 25-30% of max.
    I do recommend the stingray for someone looking for something more advanced than the boebot and less expensive than the eddie but keep in mind it really needs the more sophisticated software control. Kye has placed a good (pid) motor control in the object exchange. Here is a link to a simplified version of pid control with a decent explaination.
    http://www.ikalogic.com/closed-loop-speed-and-position-control-of-dc-motors/
