EDDIE ROBOT TURN Command not working properly
Hi I just assembled my EDDIE robot and for some reason the TURN command is not working properly. When I do 'TURN 5A 4B' (from the parallax serial terminal) which is the command for EDDIE to rotate 90 degrees at 75 positions/second, EDDIE begins to rotate but then finishes off by moving forward a little bit. I have tested it several times and each time I get a different movement, sometimes it begins to rotate stops then rotates some more (all very fast, so it looks "jittery") then moves forward slightly. Any ideas?
This is a brand new EDDIE so it has the new encoders. Firmware is 000D and when I do HWVER I get FFFF (I dont think I am suppose to be getting this HWVER number, does anyone know?).
