Rate of change Measurement
Hi Everybody,
I am a newbee here having a project idea with some difficulties:
I want to build a Rate of Change Meter on Temperature.
Input signal: analogue (from a thermocouple or LM34)
Sampling time: adjustable constant
Integration time: adjustable constant for elimination of noises
Required output: rate of change
Transmission: rate of change on serial RF line
Does anybody has such project or can help me some codes?
Any help is very welcomed
thank you very much
regards,
redrunner
thank you very much
regards,
redrunner
In any case, I'd probably start by looking at the various papers and books on numerical differentiation, such as this: http://books.google.com/books?id=lxGPQmuSwBQC&pg=PA214&lpg=PA214&dq=discrete+numerical+derivative&source=bl&ots=Jnn9OjfehR&sig=xpogU8Ifs3FT1raf3Gh_ZHSNZ_E&hl=en&sa=X&ei=dHP_UP69NYmEjAKt2YDgDA&ved=0CDwQ6AEwAg#v=onepage&q&f=false
Other than that, it's basically adding the building blocks together: code to read the sensor, code to transmit the result, and your differentiation code in the middle.
Interesting. I didn't know that "rate of change" was considered a single phrase. I parsed it to be "change" in temperature (it's "velocity"), and then the rate of that (it's "acceleration"). But, I found several sources that confirm that rate of change is indeed a single phrase.
Thanks for catching that.
Thanks for quick reply.
Rate of change of temperature gives me additional information about process to be supervised (slope of changing is a very useful extension of discreet sampling of function T(t).
I have found some lexical information about numerical differentiation at :
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CDAQFjAA&url=http%3A%2F%2Fwww.parallax.com%2FPortals%2F0%2FDownloads%2Fdocs%2Fprod%2Fsic%2FWeb-PC-v1.0.pdf&ei=Bcr_UN7cDsvDswa5xoDYAQ&usg=AFQjCNHAESjK39kXgzNOLDPnQAZL2h1ZWA&sig2=qn4L9tc7ZoUntkmq5VlP7w&bvm=bv.41248874,d.Yms
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&ved=0CDcQFjAB&url=http%3A%2F%2Fwww.parallax.com%2FPortals%2F0%2FDownloads%2Fdocs%2Fprod%2Fsic%2FWeb-PC-v1.0.pdf&ei=Mcr_UNXNJMTfsgat5oCgBQ&usg=AFQjCNHAESjK39kXgzNOLDPnQAZL2h1ZWA&sig2=jcW1IKv-JLaq6FLQiXmqZA&bvm=bv.41248874,d.Yms
If somebody has implemented such temperature monitoring application, I would be glad to have it
thanks a lot
