Smart Card Intergration
Hello
My name is Fotis and this is my first post on this forum!
I need for one project of mine to use a smart card.I saw on Parallax website the Smart Card Reader 32320.In the note says that example codes are only for BasicStamp and Propeller P8X32A.
Can i use this device with AVR μC?Has anyone used it with an AVR?I've never used BasicStamp and its hard for me to change the "plan" from AVR architecture.
Is it possible?
Is it possible?
Today i received the Parallax Smart Card Reader (32320) and 5 IS24C16A Smart Cards.
My question is what are the pins of the IS24C16A Smart Card,the manufacter pdf does not makes it clear....Anybody knows if they are the same as the IS23SC4442 ??
I made a mistake and i did not buy the IS23SC4442 that has extra security and the IS24C16A can be read by anyone....
My second question is about the Smart Card Reader and how to use the WriteProtect Pin that it is not on the assigned pins on the reader..?
Any thoughts?
If you look at the datasheets for the other smart cards, you'll see that the IS23SC4442 can also be read by anyone. It can only be written if the security code is provided.
Excuse me Sir but the documentation (about the card) does not have the pinout.About the reader,it is also don't mention anywhere about the other pins...And i take the continuity tester advise as humor,i'm not that ammateur...
Mike i do understand the pinout and i really did not have in mind that the IS23SC4442 can be read by anyone.Ofcoarse my pusrpose is to keep logg in the card so the write protection code could be very usefull to me..
Thanks for the reply!
I found this topic in this forum about the smart card pinout.
I'm kind of confused and here is why:
As you can see in the photo below theese are the pins of the reader
and in this photo is the pinout of the card
There is no pinout about the IS24C16A anywhere,the manufacture pdf has only the IC pinout of this eeprom.
My question is shouldn't the center "square" pin of the card be attached to the GND pin as shown in the IS23SC4442 pinout????
I'm afraid that a wrong pinout can damage the card,what is the correct pinout?
EDIT:
Well,thats what i call BAD LUCK!!!!I
It drove me nuts but i found a manufacture fail in one of my five cards i bought from mouser,the chip is attached in another shape and the card is useless.......
Im so happy that this is cleared out,please excuse me for the post
