Suggestion: DAC or RC (resistor, capacitor) to produce vRef
I am still somewhat new to electronics, so please forgive me if I sound ignorant.
I need to solve the following next challenge in my application.
These are the requirements:
I am trying to solve this by using a RC (resistor capacitor combination) and a PWM from the Propeller, instead of the DAC chip approach (as this would require some sort of additional power supply.) Trying to get this to work with an RC, I found that this should be almost doable using a high-speed optocoupler (25Mbs).
But -- is this the best way to do this?
I found this in a different forum http://www.edaboard.com/thread201943.html but could not get LC logic to work.
Any suggestion are welcome!
Thank you very much.
- I need to produce a reference voltage (vRef) that varies from 4 to 10 volt
- vRef is on an isolated separate circuit (behind an opto-isolator)
- vRef is controlled by a Propeller chip
- I have 24 Vdd available to power vRef
- It is critical that vRef is very steady and that it can be changed within 1/10 of a second from 4 to 10 or from 10 to 4V.
However, perhaps you could give us a bit more detail on what your project is trying to achieve. The reason I am looking for more detail is that usually you want Vref to be the one thing in your system that you can count on being what it is supposed to be.
If you agree to move Vref around between 2 or more values, you potentially introduce instability which may make your system less precise/accurate than would otherwise be achievable.
Cheers,
kwinn: will your approach required 3 I/Os? I am not too sure I understand your suggestion too well. And what about the heat?
More details to my application:
The vRef controls the brightness (intensity) of a flash (strobe) which is part on a film transfer system. So it is very important that the intensity can be held constant, once set. This is why I do like the 12bit precision that a DAC brings, in theory at least (I never used one before.)
This is what I came up with, but the problem with this approach is that the vRef is either fast enough but ripply; or too slow and more steady. I guess I will need to compromise if using this. The only way to cut down on the ripples is by having a fast optocoupler.
Thank you for your continued help!
This is the code to do an "Import" on the electronic circuit simulator java applet: http://www.falstad.com/circuit/
$ 1 5.0E-6 13.097415321081861 60 5.0 43
w 880 288 768 288 0
r 528 368 528 432 0 1200.0
w 528 288 448 288 0
g 528 464 528 512 0
t 464 448 528 448 0 1 -11.274911143780775 -1.2 100.0
p 880 352 880 288 1
r 304 384 304 448 0 180000.0
r 304 448 304 512 0 15000.0
R 304 384 304 352 0 0 40.0 24.0 0.0 0.0 0.5
g 304 512 304 560 0
R 304 448 240 448 0 2 1000.0 1.2 0.0 0.0 0.19
g 768 368 768 416 0
x 45 173 111 176 0 10 top left corner
x 730 209 933 215 0 24 to strobe 4-10 vRef
x 66 280 283 286 0 24 PWM from Propeller
g 448 352 448 400 0
R 448 224 448 192 0 0 40.0 24.0 0.0 0.0 0.5
r 448 288 448 352 0 100000.0
r 448 224 448 288 0 8200.0
w 304 448 464 448 0
w 528 288 528 368 0
c 544 246 624 246 0 1.0E-6 15.119996188726418
l 624 246 704 246 0 0.075 -5.921189464667502E-20
r 704 246 784 246 0 56000.0
c 768 288 768 368 0 4.9999999999999996E-5 10.074911143900778
w 528 288 768 288 0
x 65 309 270 315 0 24 Duty Cycle 25-75%
x 70 374 173 380 0 24 72% = 4V
x 67 405 183 411 0 24 19% = 10V
x 73 449 206 455 0 24 Optocoupler
o 10 32 0 39 5.0 5.36870912E7 0 -1
o 5 64 0 34 20.0 9.765625E-5 1 -1
http://www.systronix.com/Resource/LTC1451-2-3_12-bit_DACs.pdf
You may have to use a buffer op-amp on the output to get to 10 volts, but that's not too hard to do.
Cheers,
Only one I/O is needed for what I suggested and it does not involve PWM so it does not matter if the optoisolator is fast or slow. When the optoisolator led is on the reference voltage will be 4V, when the led is off the reference voltage will be 10V. Once the values of the resistors required to produce the desired voltages have been determined the outputs will be stable and accurate. Since it is a reference voltage the current should be low and very little heat will be generated.
Is this about what you had in mind; and will three LM317 work for this? It looks a bit involved. Did I over-do it? Thanks again for all the help. I must admit, about 30% of what was suggested would require additional studying, because it's a bit over my head!
No, what I had in mind was much simpler as shown in the attached diagram. The regulator would be switched from 10V to 4V by the optoisolator and Q1. If you need a continuous range from 4V to 10V this circuit will not work. It will provide either 10V or 4V.
As Phil suggested a low Rds on mosfet could be used in place of Q1. I would suggest using one of the 250 ohm 0.1% resistors used in 4-20mA circuits as R1 and 1K trim pots for R2 and R3. Q1 could be a 2N3904 or 2N2222, or similar small signal transistor, R4 10K, C1 and C2 are 0.1uF.
Thank you for the diagram. This helps. I am sorry for not having been clear enough about the vRef requirements. I need to be able to adjust it seamlessly, and as gradually as possibles, from 4 to 10V.
At this point my best guess is to be using a DAC. If I get 12-bit steps from 4 to 10V -- that would equals 6V/4096 = 0.015 V increment steps! Now I just need to figure out the programing around that, and what DAC to best use....
PS. I just found this driver spin code for this 16-bit DAC (MAX451) http://obex.parallax.com/objects/548/ 16-bit may be a bit overkill.
I agree, a 12 bit dac would be a good choice for this. There are several suitable SPI dacs that can be used for this along with an op amp to provide the voltage range and resolution you need.
Thank you ALL so much for all the help!
Frank: is this sort of what you had in mind; and will this still require a op amp? Link to MCP4921 datasheet
Sorry, I am so new to this....
By setting the gain of the op amp so you get 2mV per step instead of 1.465mV and have a range of 8.192V for the 4096 steps. This will make component selection less critical and allow the software to do the offset and gain adjustments digitally.
Thanks Phil. Is it possible to float the hole thing: have AVss and GND be 4V and have Vdd and Vref be 10V?
The op-amp output is your best bet.
Not quite, but feed the DAC output (a current for the one I used) into an op amp. Unless you need "really" fast response, you may get by with spin as 12 bits may need a few mS. You can get under 10 uS using assembly to send a twelve bit value. If needed, you could further trim or scale for accuracy in case 1/4096 proves a little coarse;) My test setup used the example from the LTC data sheet into a cheap dual op amp though only used one of the two in the device. Drove the device from the prop directly.
Also, the chip used was run from 5v with a 9v ref from the coppertop. Could have gone 2 in series as this one will handle up to +/- 25 volts though I have only experimented in unipolar mode. So advised, be careful of little limitations that may be conditional. The LTC8043 should do up to 25v but Vcc ~5v,but the one in your circuit as Phil notes will be max of Vdd-0.4v in one mode and Vdd in unbuffered mode. So you have a few trade-offs to consider. I will say the LTC took a bit to get working at first...
Sorry for this large image, but somehow the forums upload code is making it hard to read. So I though I would try something new.
I never used any of these components before, they are very handy to know about.
Revised diagram, now with faster optocoupler (PHOTO-IC) link to PDF
I hope this is good to go like that ...
