Using Parallax Products at Work — Parallax Forums
Dave HeinDave Hein Posts: 6,347
edited 2013-02-14 07:50 in General Discussion
My day job and my hobby activities are usually mutually exclusive, but recently I was able to use the Prop demo board for something I needed at work. The company I work for builds videoconferencing equipment, and we needed to detemine how closely our audio and video signals were synchronized. Using some of the objects in the OBEX I was able to put together a test rig that could generate an audio pulse, and a changing VGA signal, and measure the delay times using a photo-transistor and a microphone. It probably took me about 3 or 4 days to get it all working, and now I'm able to get some fairly accurate delay measurements.
It was a lot of fun to work with the Prop for my day job, and get paid for doing something that I like to do as a hobby. I'm wondering how many other people have used the Prop or the Stamp for work-related projects.
  • Shawn LoweShawn Lowe Posts: 635
    edited 2013-01-16 13:42
    That is pretty cool Dave!
    edited 2013-01-16 18:46
    I have used a few Parallax items at work for projects and yes, it is great when you can mix work and your hobbies. One is a thermistor cable harness tester, which I recently modified to also test RTD based harnesses. I also have a system for monitoring temperature and humidity for a drybox for MSD components. Unfortunately, that one is not documented at all.
    edited 2013-01-16 19:24
    All the time for quickie prototypes. I can't share due to corporate IP. Maybe I'll ask for permission to show one especially cool one done for a big movie pitch, which helped win a contract. As usual, the prototype had many more features than the final product. :)
    edited 2013-01-16 19:34
    You must've done it in C. 'Probably would've taken only a day or two in Spin! :)
    Seriously, though, quickie protos are the Propeller's fort
    edited 2013-01-16 20:07
    I only wish that fact could be commicated more effectively to Parallax's potential customers.
    Does that mean "told humorously" ? :)
    edited 2013-01-16 20:28
  • SRLMSRLM Posts: 5,045
    edited 2013-01-16 22:30
    Me? I'm working full time to develop a Propeller based system. I can't share it yet (pesky NDA), but I'm told it will all be released when it's done since the company isn't planning on making money with it directly.
    So yes, I use Parallax products at work, although it's only the Propeller. Everything else is too specific, so it's custom.
    ps: I've just recently switched over to G++, and I don't have any regrets. I really like object oriented programming for embedded systems.
  • LtechLtech Posts: 388
    edited 2013-01-17 02:06
    @Dave
    This device we use for a long time "Smartlips Set" www.bpr.org.uk. Cheap, and easy
    This is a easy way to check the delay of a camera to screen.
    The system is universal, everybody can handle this signal ....
    The metering system works within 1 frame 40ms
    I use a lot of Propellers, basic stamps at work (video broadcasting facility), and never get trouble wen I put them online. Some of them for 6 years now
  • JordanCClarkJordanCClark Posts: 198
    edited 2013-01-17 03:35
    All my Parallax projects have been work related-- which I suppose is okay, since I apparently have no time for hobbies.:lol:
    edited 2013-01-17 03:48
    I use Parallax products at work quite often.
    Not sure the bosses would be happy if they found out:)
    edited 2013-01-17 07:35
    @Phil, yes I wrote it in C and PASM. Spin if fine for hobby projects, but C is better for work projects. This way my co-workers can understand and modify the code without spending time to come up to speed on Spin. It took me 4 days because there was a small amount of hardware involved. I started out with a photo-transistor hanging on a twisted pair of wires, and found that I needed to add a transistor to the photo-transistor to get more gain. I also needed to do a few things with the audio ADC input to make it more reliable.
    @Ltech, the Smartlips product looks interesting. I'm not sure if it does exactly what I needed, but I might look into getting it.
  • JonnyMacJonnyMac Posts: 9,809
    edited 2013-01-18 08:10
    I certainly do!
    edited 2013-01-18 08:35
    I do, too! And I guess I'm additionally lucky, in that the company I work for embraces my use of Spin, probably because of the enhanced productivity it offers for rapid app development.
  • jazzedjazzed Posts: 11,803
    edited 2013-01-18 09:59
    ... the company I work for embraces my use of Spin ...
    Would you mind sharing the company name?
    I'm guessing it's one we know.
    edited 2013-01-18 10:19
  • doggiedocdoggiedoc Posts: 2,257
    edited 2013-02-13 04:48
    Does the chicken coop project count as work for me since I'm a veterinarian?
    edited 2013-02-13 08:07
    The Propeller has completely changed the way I work.
    I have a small chemistry lab and I've been able to drastically increase the speed and accuracy of testing by having data digitally recorded to a SD card.
    Adding barcodes (interfaced with a Prop) to vials and bottles has also greatly increased the speed and accuracy of testing.
    The Prop changed a job that had been very dull and tedious to one that's practically (and often actually) fun.
    edited 2013-02-13 08:18
    Please do ask erco, that sounds cool! I wish I could use parallax items at my job, but with soooo many government regulations..... :(
  • xanaduxanadu Posts: 3,347
    edited 2013-02-13 14:09
    I've probably posted this like 10x but it never gets old for me...
    I replaced an older automation controller in a Simplex 35mm projector for a small 6 screen independent movie theater. The automation controller was going to cost some astronomical number to repair or replace. I used a Basic Stamp 2 BOE board, a few transistors and some optocouplers, the rest was already there. Good times, wish I still had some pics to share.
    edited 2013-02-13 22:13
    Duane Degn wrote: »
    I'd love to hear more about how you are using a barcode reader. A lot of data input tasks are redundant and tedious. Having the Propeller read bar codes really eliminates a lot of drudgery and enhances the utility of the Propeller.
    I love barcodes and barcode readers. I no longer have to try to figure out what was written in a lab book.
    I initially used a scanner from SparkFun but I found a less expensive scanner on ebay that works even better than the SparkFun version. Both the ebay scanner and the SparkFun scanner use the same protocol.
    I have more information about this in this thread. To use the scanners with a serial connection instead of a USB connection a custom cable needs to be made (using Cat5). I give instruction about making this cable in the SparkFun's barcode reader comment section. My user name at SparkFun is "ddegn".
